Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Hardened "goop" (ferro-fluid) on midrange/tweeter speakers?
Reply
Thread Tools Display Modes
Bill Webb
Guest
Posts: n/a
      08-30-2003, 09:12 AM
I have come across several sets of speakers where one or more drivers
(midrange/tweeter) have siezed up. Opening them has revealed a black,
sticky tar-like (or harder) substance between the coil and magnet,
restricting motion of the coil. I assume this is (or was at one time)
ferro-fluid coolant. Is this correct? What causes it to harden this way?
Finally, is there any proper way to clear out this gunk or otherwise
restore the driver to normal?
Just recently I have picked up what would otherwise be a *beautiful* set
of speakers, except for a siezed-up midrange driver as described above.
While waiting for a response from the manufacturer about a replacement,
I figured I would see if it could be temporarily rejuvinated until the
replacement arrived - I put in a drop of nail polish remover to loosen
the gunk, removed as much as I could without making a project of it,
then fed in a couple drops of light machine oil (to roughly approximate
the original composition of the ferrofluid) and let the driver exercise
overnight on a signal generator. To my utter amazement, this hamhanded
ghetto-rigging actually worked! This driver sounds about the same (a
little louder, in fact) as the other. I don't know for how long, though,
but now it looks like I will be finding out: the maufacturer replies
that the part has been discontinued
Jim Adney
Guest
Posts: n/a
      08-31-2003, 04:15 PM
I believe ferro-fluid is just a mixture of oil and finely ground iron
(or some other magnetic material.) Your description sounds like the
oil has gotten overheated and either slowly evaporated or oxidized and
thickened. My first thought was to just try adding some heavy (low
vapor pressure, so it won't evaporate quickly) oil and see if it mixes
with what is in there and loosens up the speaker.
A better way to proceed might be to dig out a bit of the thick stuff
and try adding various oils to it to see what it seems to be happy
with.
Jim Adney (E-Mail Removed)
Madison, WI 53711 USA
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
$BnyS4;:IJ(BIGCT$B!"(BIGBT$B!"(BGTR$B!"(BIPM$B!"(BPIM$B!"2D95(B$Bbk!"@0N.66!"2w2zJ#Fs6K4I!"Fp2zJ#Fs6K4I(B. 〓專業IGBT銷售〓 Electronic Design 0 10-11-2008 06:34 AM
Medical Records On Escorts Darya "Dasha" Gunchenko and Rajni "Sonia"Parmar - RELEASED ffxff Electronic Repair 0 06-25-2008 11:50 PM
Philips 60" RPTV - New cooling fluid, clean lenses and mirror, still "cloudy" samsungfirmware@yahoo.com Electronic Repair 8 10-07-2006 06:22 PM
Re: Arny Krueger deliberately sabotages ABX "I don't really have a replacement career," Morein said. "It's a very gnawing thing." Robert Morein Hobby Electronics 13 10-08-2005 02:37 AM
Whats the difference between "resolution" and "effective no of bits" for Analog to Digital Converter sagar Electronic Basics 2 07-23-2004 03:05 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
