Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Harddisk motion detection?
Reply
Thread Tools Display Modes
Bart Bervoets
Guest
Posts: n/a
      10-03-2006, 01:05 PM
Is it possible that inside certain harddisks motion detectors are placed?
I have a harddsk which works fine but as soon you move the drive (powered on
and connected to pc)
the head sounds as it wants to go in park, if i leave the drive alone it
just works fine.
IDE and power cable are ok.
Not relevant for a repair but plain curiosity, i would expect it on a laptop
disk but not a desktop.
Bart Bervoets
Meat Plow
Guest
Posts: n/a
      10-03-2006, 01:23 PM
On Tue, 03 Oct 2006 15:05:22 +0200, Bart Bervoets Has Frothed:
> on and connected to pc)
> just works fine.
> laptop disk but not a desktop.
> Bart Bervoets
I can safely say that no modern drive has any such thing.
Pierre Salinger Memorial Hook, Line & Sinker, June 2004
COOSN-266-06-25794
Sam Goldwasser
Guest
Posts: n/a
      10-03-2006, 02:09 PM
Meat Plow <(E-Mail Removed)> writes:
> > just works fine.
> > Bart Bervoets
Some laptops and external harddrives for laptops do have shock detectors but
I don't know if they are inside the drives.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Clyde Crashcup
Guest
Posts: n/a
      10-03-2006, 03:24 PM
> just works fine.
> Bart Bervoets
You should never move a running drive. It could crash.
50% of all statistics are wrong. The rest don't matter.
Clyde Crashcup
Meat Plow
Guest
Posts: n/a
      10-03-2006, 03:49 PM
On Tue, 03 Oct 2006 15:24:23 +0000, Clyde Crashcup Has Frothed:
>> placed? I have a harddsk which works fine but as soon you move the drive
>> (powered on and connected to pc)
>> just works fine.
>> Bart Bervoets
LOL that made me laugh.
COOSN-266-06-25794
David Nebenzahl
Guest
Posts: n/a
      10-03-2006, 05:09 PM
Meat Plow spake thus:
>>>just works fine.
Yeah, I guess all those people using laptops must just *imagine* they're
moving their computer while it's on.
Save the Planet
Kill Yourself
- motto of the Church of Euthanasia (http://www.churchofeuthanasia.org/)
James Sweet
Guest
Posts: n/a
      10-04-2006, 02:57 AM
> just works fine.
> Bart Bervoets
Most microdrives have this feature, but these are the tiny drives the
size of CF cards used in many portable music players. Just moving it
should not trigger it though, it takes a fair bit of shock.
William R. Walsh
Guest
Posts: n/a
      10-04-2006, 06:09 AM
Hi!
Anything is always possible. But I doubt that there is any such thing in a
desktop hard drive. Laptop drives may have such circuitry in place.
Based on some drives that I've worked with over time, I'd say what you're
seeing is likely a result of the spindle motor somehow changing speed
slightly as you move it. The drive's controlling electronics can monitor the
RPM of this motor and may shut the drive down if enough of a change is
detected. The motor may be getting ready to fail or it may have worn
bearings that allow a significant RPM change when you move it.
You can get most desktop drives to reinitialize themselves with a mild tap.
I don't suggest trying that on a drive you depend upon. And while it
generally does no harm to move a running hard drive, you should be careful
not to drop, jar, shake or abuse it while it is running. If any one of those
things were to happen while the drive was running, a head crash or other
drive failure is possible.
William
Homer J Simpson
Guest
Posts: n/a
      10-04-2006, 06:35 AM
"William R. Walsh" <(E-Mail Removed) m>
wrote in message news:ceIUg.89757$aJ.137@attbi_s21...
> tap.
> those
One notorious 10 Mb hard drive Radio Shack sold would only start after a
weekend if you first dropped it about a foot onto a desk!
Morse
Guest
Posts: n/a
      10-05-2006, 12:43 AM
"Homer J Simpson" <(E-Mail Removed)> wrote in message
news:JCIUg.50909$E67.45445@clgrps13...
I've seen many, many drives like that- it's called 'stiction'. The heads and
platters are so perfectly formed and smooth that they can bond together
preventing the drive motor spinning up the platters. Usually the motor can
be heard pulsing and giving up after a few tries. The best way to release
the heads from the platters is IME to hold the drive and quickly flick it in
a rotational plane to spin the internal platters breaking the bond. Freezing
the drive overnight can also do the trick, but the drive must be put in a
completely sealed bag beforehand. Warming with a hairdryer can also help.
Thumping the drive onto a hard surface should be a last resort.
Stiction is not usually an issue on modern drives, but it was common on the
old MFM/RLL/ESDI style drives.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Outdoor motion detection help Noweldrecumbent2 Security Alarms 15 05-27-2007 06:18 AM
Video Motion Detection Luhan Electronic Design 24 07-23-2006 05:54 PM
Re: Cameras and Motion Detection for Home? gothika Security Alarms 2 02-02-2004 11:00 PM
Re: Cameras and Motion Detection for Home? SQLit Security Alarms 0 11-17-2003 10:57 PM
Re: Cameras and Motion Detection for Home? Rob Security Alarms 0 11-17-2003 12:29 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
