Electronics Forums
Electronics Forums > Electronics Forums > Electronic Projects > Got a question about driving LEDs? (Another work in progress)
Reply
Thread Tools Display Modes
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      11-21-2010, 01:19 PM
OK, lots of people ask questions about driving LEDs. So here's a list of common answers and pointers to documentation that is useful.
But not any more...
Thanks to a lot of feedback and valuable assistance by many members, this has achieved a maturity that I think deserves a place in our tutorial section.
This thread remains for any comments you might have, and also because many existing threads refer to it.
Member
janagyjr's Avatar
      12-18-2010, 03:55 PM
Oh, in that case it's brilliant, hehe. (: I was just wondering what else could be added to it. Though if you set out to speak generally on the subject it's golden. Might want to lock the topic.
Senior Member
barathbushan's Avatar
      12-30-2010, 04:31 AM
Here's a calculator for the resistor to be attached in series with an LED
http://home.cogeco.ca/~rpaisley4/LEDcalc.html
Hope it helps !!
Super Moderator
(*steve*)'s Avatar
      12-30-2010, 08:53 AM
Quote:
No, and for 2 reasons. Firstly, I am under no illusions that my statement is the final word on the topic, and secondly, sticky threads are great bait for spammers.
Hope it helps !!
Thanks, I've added that one.
Junior Member
      03-16-2011, 01:08 PM
its agreat material realy helped me alot....thumbs up....
Junior Member
      05-17-2011, 12:49 PM
Great work indeed
Senior Member
      07-15-2011, 09:29 AM
Hi Steve
Great exposition!
What is the purpose of the capacitors in output of the switch mode current source?
What happens if there is no load, do the capacitors go pop?
Junior Member
      08-06-2011, 12:27 AM
Few suggestion on improving the thread:
More info about practical issues such as what power supplies/resistors/capacitors/constant current psu's etc. are widely available rather that just pure maths because if for example you calculate the voltage needed and it's 13 volts then it might be hard for a new comer to figure out which psu to get.
Better explanation of diagrams. Like duke37 asked about the capacitor, I don't really know what it's for either but seen it in many diagrams b4. Also I looked for 0.1uF capacitor and I didn't see anything even close to this value, so more info would be nice.
More info on complex/unusual setups as this is where people have problems most of the time. Like 3x3W led's or 12W led's
Mostly more info and some examples on how to actually wire the led's and constant current circuits especially the ones with unusual requirements, such as the 3 led psu problem (~3x3+4.25=13.25V this is just over usual 12V power supply, is there a way to still use the 12V supply such as by wiring led's in parallel?).
Hope this helps with the brainstorming
Junior Member
      08-06-2011, 12:33 AM
Also, this is a useful LM317 calculator, maybe it's worth linking to it from the main post...
http://diyaudioprojects.com/Technica...age-Regulator/
Senior Member
      08-06-2011, 05:36 PM
Steve
I think the thread is pretty good as it stands. It is difficult to give one explanation to those of very different abilities. It is often necessary to explain in several ways before the penny drops, when it does, it is very satisfying.
One of the problems is to explain that there are often many ways of doing the same job and compromises can sometimes give more simplicity with almost the same performance.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Has anyone got this universal analog output circuit to work? leeb_965 Electronic Projects 5 02-06-2012 01:51 PM
mControl: Anybody Got Insteon Motion Detector To Work? (PeteCresswell) Security Alarms 2 07-12-2009 08:28 PM
Hurrah!! Got my transmittor to work NJM Electronic Basics 6 03-17-2007 11:57 AM
opamp driving power transistor driving coil Jon Electronic Design 6 09-06-2004 05:13 PM
