Paul B <(E-Mail Removed)> writes:
> I am looking for some 1-to-1 matching transformers to connect varioua
> audio devices to my PC. I usually get noises and hum.
Here are some of my experiences on making mu own such devices:
http://www.epanorama.net/documents/g..._building.html
> These line matching transformers are not so cheap at about £6 or 7
> each.
Good quality transformers seem to cost considerable amoutn of money.
> Telephones seem to suppress line noise and hum rather well so I
> figure the components they use are probably of half-decent quality.
600 ohms 1-to-1 matching transformers are quite rare in telephones.
Modern normal telephones are normally "floating" line powered
devices where electronics connect directly to line. The whole
small device is "floating" isolted from everythign else
so that gives good balance.
You can find 600 ohms 1-to-1 matching transformers most often
on modems. And those are also in some telephones that use
external power...
> If I strip down some landline phones I 've got here, then will there
> be a matching transformer in each one?
Propably not any transformer in a modern phone at all.
And in older ones where there was a transformer that is most
propably not a type of transformer you are looking for
(for details on transformers used at beginning of
http://www.epanorama.net/documents/t...interface.html
document).
> Or is their technology different now?
Tomi Engdahl (
http://www.iki.fi/then/)
Take a look at my electronics web links and documents at
