Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Generating differential signals
Reply
Thread Tools Display Modes
ELECTRONICS
Guest
Posts: n/a
      02-21-2006, 09:20 AM
I am trying to carry out some testing for different communication
protocols. I am stuck at generating differential signals. There is no
equipment available that can directly generate it and I can use for
analysis. Any idea on how a single ended signal can be used to generate
differential signal and used. I am loking at frequency higher than 1
GHz.
Cheers
PeteS
Guest
Posts: n/a
      02-21-2006, 09:43 AM
> GHz.
> Cheers
Both Tek and Agilent carry test and measurement solutions for
differential high speed communications layers. (I have used their
equipment in DDR InfiniBand - 5Gb/s, 2.5GHz fundamental)
Try this:
http://www.tek.com/Measurement/appli...data_apps.html
Cheers
PeteS
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
CCt to converter 24Vdc signals to 12Vdc signals Joe G \(Home\) Electronic Design 1 06-08-2010 11:44 AM
How to measure non differential signal with differential ADC? Michael Noone Electronic Design 10 02-24-2005 04:08 PM
generating negative air ions Charles P Lamb General Electronics 13 02-13-2005 07:25 PM
Automotive - using turn signals as combo turn signals and running lights Greg Bender Electronic Basics 3 01-03-2005 12:10 AM
Generating a schematic from a net list ? Peyter Electronic Basics 3 11-20-2003 08:53 AM
