Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Floppy Drive from one Laptop into Another Laptop
Reply
Thread Tools Display Modes
Brad
Guest
Posts: n/a
      09-13-2006, 06:26 PM
The floppy drive, part # 261848-001, in my 1997 (abt.) Compaq Presario
1060 laptop is bad and there is no replacement available. Note: I service
TVs, etc., rarely computers. I have a floppy drive from another model Compaq
laptop, not the same part number, but it could fit in the space occupied by
the original. What is your opinion?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
Don Bowey
Guest
Posts: n/a
      09-13-2006, 08:23 PM
On 9/13/06 11:26 AM, in article (E-Mail Removed),
"Brad" <(E-Mail Removed)> wrote:
> Hi,
In my opinion all 1.44 MB floppies are the same. I don't even look at their
part numbers when I change one out.
Don
Puckdropper
Guest
Posts: n/a
      09-13-2006, 09:14 PM
Don Bowey <(E-Mail Removed)> wrote in
news:C12DB6C3.42FB1%(E-Mail Removed):
> their part numbers when I change one out.
> Don
Be careful if you work on PS/2s. Very little was standardized in those
not even the floppy drives!
Puckdropper
Wise is the man who attempts to answer his question before asking it.
To email me directly, send a message to puckdropper (at) fastmail.fm
Art
Guest
Posts: n/a
      09-13-2006, 10:50 PM
Agreed the floppies are probably the same but the actual priority device
that reads and writes to them are different depending on manufacturer,
sometimes model numbers, etc. That is, a floppy drive unit from a SONY will
not work in a DELL, nor a Old HP in a new Compaq.
"Puckdropper" <(E-Mail Removed)> wrote in message
news:450874c2$0$97265$(E-Mail Removed) reenews.net...
>> Don
> Puckdropper
Allodoxaphobia
Guest
Posts: n/a
      09-13-2006, 10:55 PM
Yep. I remember that the PS/2 either inverted the meaning of the
write-protect slider, or totally ignored it.
( For you kiddies reading this and wondering:
( No we are not speaking of the Play Station 2.
Jonesy
Marvin L Jones | jonz | W3DHJ | linux
38.24N 104.55W | @ config.com | Jonesy | OS/2
*** Killfiling google posts: <http//jonz.net/ng.htm>
Michael Black
Guest
Posts: n/a
      09-13-2006, 11:37 PM
Don Bowey ((E-Mail Removed)) writes:
>> Hi,
> Don
But does that apply to laptops? They often do use proprietary parts,
which is why extra parts are often so expensive. It likely also
depends on vintage, the further back in time the more likely it is
a unique device to that laptop.
Michael
Art
Guest
Posts: n/a
      09-15-2006, 10:51 AM
As posted earlier, the media, the 1.44 floppies are universal, however the
actual mechanical drive assemblies are proprietary, even in some cases
machine to machine in the same manufacturer. You will require the correct
device to fit back into the Compaq Laptop.
"Michael Black" <(E-Mail Removed)> wrote in message
news:eea4nk$s2d$(E-Mail Removed)...
>>> Hi,
>>> Presario
>>> service
>>> Compaq
>>> by
>> their
>> Don
> Michael
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Toshiba Satelite Pro laptop 440CDX floppy Andrew Tweddle Electronic Repair 6 10-19-2006 01:16 PM
need scehmatics on Teac 3.5 laptop floppy drive anglomont@yahoo.com Electronic Repair 1 10-05-2006 09:19 PM
Compaq Armada 1520DM Laptop CD Rom Drive Problem Brad Electronic Repair 1 02-25-2006 02:37 PM
Re: Compaq Armada 1520DM Laptop CD Rom Drive Problem Brad Electronic Repair 0 02-25-2006 01:11 PM
laptop floppy ducran lapoigne Electronic Repair 3 09-29-2003 04:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
