MRW wrote:
> Sorry for all the questions. I'm just curious.
> In reading, Texas Instrument's Single Supply Op Amp Circuit Collection
> guide, I found this attenuator circuit:
> http://img360.imageshack.us/img360/8...enuatorpj3.jpg .
> It says that the input resistance should be split into two: RinA and
> RinB. So I figure that the input resistance would be RinA + RinB.
> In general, however, how do I go about my analyses to find the input
> resistance?
Think of all fixed voltages (ground, Vcc and Vcc/2) as zero
ohm points as far as signal current is concerned. An
inverting opamp also uses feedback to hold its - input at
the same voltage as is applied to its + input, so that node
can be considered to be a zero ohm to ground node as far as
signals are concerned.
As to the best values for all those resistors, it depends on
what attenuation or gain you want, and whether or not the
output can absorb all the input current through the feedback
resistor, or if you want some of the input current to pass
through R3 to Vcc/2. If you are not concerned with keeping
the input impedance low input impedance to some low value
with R3, R3 is not needed. So the best answer depends on
all the design constraints. lots of combinations will work
under some conditions.
> I get confused easily when looking at the circuits. An example is this
> page: http://www.geocities.com/ferocious_1...icpreamp2.html ... It
> says that the two 27k ohm resistors are in parallel. How?
Each of them loads AC signals with a path to some fixed
voltage. From an AC analysis point of view, all fixed
voltages are ground.
> The reason why I want to know about the input resistance is because
> according to http://tangentsoft.net/audio/input-cap.html, the input
> capacitor value will be dependent on the series resistor and the
> specified cut off frequency.
> Thanks!
