Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > How to find missing resister with a given voltage value?
Reply
Thread Tools Display Modes
alishadevochka@gmail.com
Guest
Posts: n/a
      06-19-2007, 03:19 AM
I have two circuits, where resister voltage are given, and I need to
find resistor value.
first circuit is -- both are serial circuits
E= 24v, R1 = 2ohm, R2=4 ohm, and R3= 24W (watts).
Find R. How do I do this, Also please explain the method.
Second question is
E = 20V, R1=2V, R2=40ohm, R3=32ohm. Find resistor R1 using voltage
divider rule.
This is what I have done so far for;
formula; v1 = R1*E/R1
2v=R1*20v/R1
2V=20V
=10ohm
I use this method on another serial circuit with all the ohms,
current, voltage, and I didn't get the right answer. There are no
answer at the back of the book, and I don't know if I am right.
John Popelish
Guest
Posts: n/a
      06-19-2007, 04:32 AM
You have one simple formula relating I to V for R3. I*V=24,
or I=24/V or V=24/I.
You need to come up with a second formula relating I and V
to R value based on the other two resistors and total
voltage. Then combine these two formulas to solve for R3.
The voltage across R3 must be 24 - R1 drop - R2 drop. Each
of these drops is pretty easy to describe in terms of the
common current, which is also pretty easy to describe in
terms of R3.
> Second question is
> divider rule.
The divider rule is
fraction of total voltage that is dropped across Rx
= Rx/Rtotal
So, in this case Vfraction = 2/20 = 0.1
=R1/(R1+R2+R3)
> 2v=R1*20v/R1
> 2V=20V
> =10ohm
Eeyore
Guest
Posts: n/a
      06-19-2007, 09:11 AM
You can do this with Ohm's Law.
Do you know it ?
Graham
Fred Bloggs
Guest
Posts: n/a
      06-19-2007, 10:36 AM
> Second question is
> divider rule.
> 2v=R1*20v/R1
> 2V=20V
> =10ohm
In both circuits E=I*(R1+R2+R3) and you have to solve for an unknown R,
which means you must eliminate I from the equation.
In the first circuit you are given the power in R3 is 24W which I^2*R3
so that I=sqrt(24/R3) and the equation becomes:
E=sqrt(24/R3)*(R1+R2+R3), or 24=sqrt(24/R3)*(6+R3), which you can now
solve for R3.
In the second circuit you are given the voltage drop across R1 is
2V=I*R1 so that I=2/R1 and the equation becomes E=2/R1*(R1+R2+R3), or
20=2/R1*(R1+72), which you can now solve for R1.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
OT: Philosophy: Pick one ....Given the Truth or Given the Drive for Truth D from BC Electronic Design 13 02-14-2010 04:34 PM
how to find out internet access given utp cable using the smallest devices? computer Electronic Repair 0 12-04-2005 01:58 AM
How do you find Carrier Amplitude for given AM wave signal sam General Electronics 2 04-30-2004 06:17 PM
Need Force Sensor(Resister, Switch??) S General Electronics 3 02-17-2004 03:57 AM
help to find out the value of a base resister to a transistor Andrew Crook Electronic Design 10 12-21-2003 07:51 PM
