Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Hobby Electronics > etag transponders
Reply
Thread Tools Display Modes
etag transponders
F Murtz
Guest
Posts: n/a
      01-19-2009, 11:23 AM
are etags "active" if so the batteries must be good to last so long in
that environment and temperatures on glass inside windscreens.
if they are passive where do they get the beep
dmm
Guest
Posts: n/a
      01-19-2009, 11:51 AM
Dunno about other etags, but the wife's etag has a Saft 3.6V lithium battery.
Bob Parker
Guest
Posts: n/a
      01-19-2009, 01:59 PM
The data sheet for the ones supplied by the NSW RTA is at
http://www.q-free.com/images/stories...ets/MD5888.pdf
F Murtz
Guest
Posts: n/a
      01-19-2009, 02:19 PM
>>> in that environment and temperatures on glass inside windscreens.
>> battery.
thanks
Mr.T
Guest
Posts: n/a
      01-19-2009, 09:04 PM
"F Murtz" <(E-Mail Removed)> wrote in message
news:497462ad$(E-Mail Removed)...
The tolling companies replace the etags when the batteries go flat.
MrT.
kreed
Guest
Posts: n/a
      01-20-2009, 12:40 AM
from the pic supplied from bobs link, those batteries (in RAM backup
applications) I have found
will last 20 years (measured full terminal voltage when replaced).
Depending on the transmission
power, and how often, as well as the sounder and how often its
activated, a long life is quite viable.
I didnt think any battery would cope well with the temperatures
involved, especially when placed at the highest (hottest) point in the
car (upper windscreen)
David L. Jones
Guest
Posts: n/a
      01-20-2009, 01:42 AM
They most likely use the 120degC rated Lithium-thionyl chloride cells.
http://www.saftbatteries.com/Technol...3/Default.aspx
I've used (and thermal cycled) them in operating apps from 0degC to
80+degC (ironically in two of the listed apps - sonarbuoys and oil
exploration), they are remarkably durable.
Dave.
Techo
Guest
Posts: n/a
      01-20-2009, 07:49 AM
I got one of the RTA tags when they first came out. The battery died after
about five years, the RTA then replaces it for free. When you ring them,
they can look up on their system to see ;your signal strength from when you
have been travelling through their tolls.
"David L. Jones" <(E-Mail Removed)> wrote in message
news:1450d517-5b7b-4042-bbb4-(E-Mail Removed)...
in
battery.
> Dave.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
RFID: Active Transponders + Reader (Long Range - 20-40m) Bobby Sardana Electronic Equipment 6 12-24-2004 01:59 PM
Re: Active Transponders + Reader (Long Range - 20-40m) Watson A.Name - \Watt Sun, the Dark Remover\ Electronic Design 0 12-24-2004 01:59 PM
Re: Timing using Transponders Iain Wilkie Electronic Design 2 08-09-2004 12:19 PM
Re: Timing using Transponders dmm Electronic Design 0 08-09-2004 12:16 PM
Re: Timing using Transponders Genome Electronic Design 4 08-08-2004 09:50 AM
