On 5 Feb, 12:28, "petrus bitbyter"
<pieterkraltlaatdit...@enditookhccnet.nl> wrote:
> "SBS" <no.s...@grazie.da.me> schreef in berichtnews:45c703b6$0$31680$(E-Mail Removed) .tin.it...
> > Hi,
> > I am looking for an electronic ballast which
> > could drive 8W fluorescent lamp(s) (UVA tube).
> > I found some electrical schemes on the web, but
> > I wasn't be able to find the suitable transformer.
> > Can someone tell me about a good ballast design,
> > please?
> > Thank you and regards.
> You can drive an 8W fluorescent lamp with a simple circuit that requires no
> coil or transformer.http://www.repairfaq.org/sam/linefl.gif
This circuit looks like a typical 'play around with lots of components
but ensure you do not know anything about what you are doing' type
circuit.
On 220V ac a single series cap will work as a ballast. Since many (but
not all) 8W T5 tubes's, at room temp, will begin to arc as low as 250V
- that is all that is needed.
>From memory the arc is run at around 50V for a T5 8 watt.
With a capacitive ballast the crest factor is appalling, the cathodes
will be stripped etc, life and output reduced. That is why it is not
used.
Why do you need an 'electronic' ballast?
What is the advantage of an electronic ballast in your application -
size, thermals,..... ??
