Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > Efficient Refrigerators - cheap????
Reply
Thread Tools Display Modes
East-of-lake
Guest
Posts: n/a
      01-23-2004, 12:21 AM
Sunfrost's electric or one of the gas/propane units are very efficient but
all of them are expensive. It's a toss up whether the Sunfrost is cheaper
than buying a "normal" refrigerator and putting the savings into extra PV
capacity.
Don't any of the "mass market" manufacturers make any high efficiency
refrigerators and freezers? This isn't rocket science; a smaller compressor
with 1/4 to 1/2 inch thicker insulation would to wonders for power
consumption. Surely GE, Kenmore, etc could sucessfuly market them.
Lee Smith
Guest
Posts: n/a
      01-23-2004, 01:48 AM
> capacity.
> compressor with 1/4 to 1/2 inch thicker insulation would to wonders for
> power
If you look at : www.aceee.org/consumerguide/topfridge.htm
they list a few of the "top performers" including:
Sunfrost RF-16 with 14.31 cubic feet using 254 kWh/year
Kenmore 6397*30* with 18.79 cubic feet using 392 kWh/year
and many others..
Lee
Ben Simons
Guest
Posts: n/a
      01-23-2004, 09:21 AM
Am Thu, 22 Jan 2004 16:21:53 -0800 hat East-of-lake <(E-Mail Removed)>
geschrieben:
> but
> cheaper
> capacity.
> compressor
They do, at last european companies. They are at about 10kWh/feet^3/year
(if i have done the conversions right). This number depends on the ambient
temperature. Perhaps the european test-procedure is different than
US-test. Who knows?
--> See www.topten.ch (german). Klick on "Haushalt/Kühlschränke"
--Please answer to the group, not the email-address. Thanks
nicksanspam@ece.villanova.edu
Guest
Posts: n/a
      01-23-2004, 04:00 PM
....17.7 kWh/ft^3-year, or 7.2 kWh/ft^2-year, as
a 14.31 ft^3 cube with 35.4 ft^2 of surface...
....20.9 kWh/ft^3-year, or 9.2 kWh/ft^2-year.
Ben Simons <(E-Mail Removed)> wrote:
>...european companies...are at about 10kWh/feet^3/year (if i have done
>the conversions right). This number depends on the ambient temperature.
>Perhaps the european test-procedure is different than US-test. Who knows?
Maybe you could compare the European and US standards.
The most efficient at "16-38C" ambient temp is the Candy CPDC 320AA plus,
with a 253 L (8.9ft^3) combined fridge/freezer cap and a 203 kWh/year
consumption, ie 22.7 kWh/ft^3-year, or 7.9 kWh/ft^2-year.
I like the heat pump clothes dryers and drying closets. The hot air dryers
also look more efficient, at about 0.3 kWh/kg, with a 5-6 hour drying time.
The horizontal-axis washers also take longer, use less water and soap and
energy, and heat their own water. How much of this stuff would run on our
240 V 60 vs 50 Hz?
Nick
Ben Simons
Guest
Posts: n/a
      01-23-2004, 04:54 PM
If you have 16C or 38C makes a BIG difference I think.
> dryers
> time.
> 240 V 60 vs 50 Hz?
Hmm We have 230/50Hz in CH. Hmm, interesting question.
More Frequency->Motor is faster-> dryer/machine runs faster (20%).
Probably too much for a washing machine??
More Voltage -> Heating is faster too (9%,U^2)
Since Bosch AEG,Liebherr, Electrolux etc are big companies they probably
have devices with other tensions/frequencies. Check it out.
> Nick
Chris Torek
Guest
Posts: n/a
      01-25-2004, 03:17 AM
In article <news:burgeg$(E-Mail Removed)>
<(E-Mail Removed)> writes:
[snippage]
>240 V 60 vs 50 Hz?
I bought a Miele washer/dryer set; it works fine on 240V 60Hz but
"wants" 15 amp instead of 30 amp breakers. Miele include a kit that
plugs into the 240V 30A dryer socket and presents two European-outlet
15A circuits, each with its own breaker. The washer, at least, uses
a variable-speed DC motor with up to 1600 RPM on the spin cycle,
so the change in frequency is no problem there. (The dryer is also
electronically controlled, but has a single speed as far as I know,
so there is no reason it would particularly *need* a DC motor.)
(First machine I ever used that got the rust stains out of my old
gym shirt. But the rust chewed up the cotton fibers, so now I have
a line of small holes instead. :-) )
In-Real-Life: Chris Torek, Wind River Systems
Salt Lake City, UT, USA (40°39.22'N, 111°50.29'W) +1 801 277 2603
email: forget about it http://web.torek.net/torek/index.html
Reading email is like searching for food in the garbage, thanks to spammers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
LG GL181PP Refrigerators Ayushi Mehra Electronic Basics 0 06-24-2008 07:39 AM
LG GL181PP Refrigerators Ayushi Mehra Electronic Design 0 06-24-2008 07:31 AM
Good resource to get the full, straight story on refrigerators, efficiency, etc. Doc Electronic Repair 8 07-13-2007 03:57 PM
Can someone point me to an efficient easy to make led circuit that is efficient on batteries? SA Development Electronic Basics 3 03-11-2005 04:48 PM
A bit ot : disassembling refrigerators Arpit Hobby Electronics 23 01-08-2004 12:26 PM
