Quote:
Originally Posted by tomrei
Hi there,
this group looks pretty spamed, but i'll try my luck.
does any one knows how to make a constant power load in the LTspice?Ren
I've come up with a couple of very easy ways to create constant power loads in LTspice. One is a resistor whose resistance is a function of the voltage across it, and the other is a voltage-dependent current source using a piece-wise linear approximation. Both are bounded to prevent convergence problems, and they work very well for most applications.
The newsgroup software is blocking my attempts to post a link because I haven't posted here before, so I'll do a followup with the link in a couple of minutes.
