Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > D52W something, ITC222 chassis
Reply
Thread Tools Display Modes
ZZactly@aol.com
Guest
Posts: n/a
      07-01-2006, 05:27 AM
Had this set come in, it did need a cord, but it needed other things. I
am not sure if we put a fly in it, but that sounds right. I had pulled
the chassis out and was unaware that the ribbon cable had pulled off
the CRT socket board.
Well, the set was hooked to a grounded antenna and not in isolation.
When they crimp those wires into the plug, the ends are bare. I can
attest to this because it touched the heatsink of the standby chopper,
which is on the primary side.
There are alot of grounds in this thing and luckily all it blew out was
a buffer stage coming out of IX400 IIRC, the TDA9330H. I repaired the
problem, it had not fried the whole board, I had to replace a
transistor and resistor in the final buffer stage to the CRT boards, I
got the red back. It was working. (IV400 ?)
Whatever it is, it is a TDA9330H, and is now not putting out H drive. I
KNOW this board worked, I KNOW because there is evidence of my repair
to the red channel. Yet now there is no H drive.
I checked all Vccs, inputs to the stages between the 12Mhz and the scan
frequency. This chip does not have shutdown, except by bus control. Now
a somewhat logical assumption could be that the chip got zapped that
day and still worked for a little while. The red output was indeed hit
with the negative side AC rectified while grounded. (isolation was
running another set at the time, I thought it would be OK, dummy huh)
I distinctly remember fixing the red channel, I did, I remember
distinctly that I at least corrected the problem I created. This could
only happen if the board works. Right ? It did, I know it did, I swear
it did.
Now there is no H drive, which comes out of the same IC. Think I
"shocked" the IC into failing ?
There is one other possibility, RCA did not use this, but there is a
bit in the I2C you can set to disable Hdrive. What are the chances that
the OS is screwed up and it will simply set the same bit in a new IC to
the same state ?
Thanks.
JURB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
RCA D52W19B ITC222 chassis 52 inch HD RPTV intermittent problem. laseranddvdfan@aol.com Electronic Repair 2 04-15-2008 02:15 AM
ITC222 question(s) ZZactly@aol.com Electronic Repair 0 01-16-2008 02:10 AM
ITC222 ZZactly@aol.com Electronic Repair 0 07-12-2006 03:08 PM
Growing Pains on ITC222 chassis (like D52W20BYX1) so on. Jason D. Electronic Repair 0 09-17-2004 02:03 AM
ITC222 chassis issues. (COMMON!) Jason D. Electronic Repair 0 09-09-2004 02:03 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
