Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Computer room static blowing server power supplies
Reply
Thread Tools Display Modes
T
Guest
Posts: n/a
      04-04-2006, 08:41 PM
A raised floor server room with 6 servers, fiber optic patch panels, large
control system cabinets and large UPS system, has been recently been plagued
by computer power supply failures. The supplies fail when apparently many
tens of thousands of volts jump from inside the PS around the switching
regulators to the chassis of the supply taking out all the components. This
has happened to 8 supplies so far. A visible blue flash has been witnessed
several times by pewrsons in the room.
The servers so far affected are all sitting on the raised computer center
floor. What ususally happens seems to be when a person enters the 12x20ft
room or gets near a server a large snap is heard and the server is on the
backup redundant PS, if it has not already failed.
We have been adding grounding bonding from all computer case to the bldg
steel, raised floor structure, etc to try to stop this. Its still happening.
The computers are various brands and varoious ages, from 1 week old to 5
years old. The probelm began occuring 2 months ago. The data center was
built 12 years ago.
We are at a loss to figure out how the charge is building up on the inside
of the power supplies. I am thinking about the common power source, via the
power cords Hot, Neutral and Ground conductor.
The green wire should be bonded to the PC case. Apparently the PS regulator
board floats above chassis potential. Apparently a large potential differnce
is building. It jumps a 1 inch gap to the chassis. Burn marks from repeated
arc overs are evindent (the arc that makes it fail is not the 1st time it
occurs!)
The Hot and Nuetral..how could a charge be coming in on these conductors and
getting past the MOVs to build a potential on the boards.
Any ideas would be appreciated.
TJS
GregS
Guest
Posts: n/a
      04-04-2006, 08:57 PM
>built 12 years ago.
>occurs!)
It sounds like your UPS's should take care of everything.
I woulds have the UPS's checked out. I would have building electricians
check things out. I would have installed whole circuit transient protection
at the breaker box feeding the room.
greg
Ban
Guest
Posts: n/a
      04-04-2006, 09:28 PM
> large control system cabinets and large UPS system, has been recently
> been plagued by computer power supply failures. The supplies fail
> when apparently many tens of thousands of volts jump from inside the
> PS around the switching regulators to the chassis of the supply
> taking out all the components. This has happened to 8 supplies so
> far. A visible blue flash has been witnessed several times by
> center floor. What ususally happens seems to be when a person enters
> the 12x20ft room or gets near a server a large snap is heard and the
> server is on the backup redundant PS, if it has not already failed.
> bldg steel, raised floor structure, etc to try to stop this. Its
> still happening. The computers are various brands and varoious ages,
> from 1 week old to 5 years old. The probelm began occuring 2 months
> ago. The data center was built 12 years ago.
> inside of the power supplies. I am thinking about the common power
> source, via the power cords Hot, Neutral and Ground conductor.
> regulator board floats above chassis potential. Apparently a large
> potential differnce is building. It jumps a 1 inch gap to the
> chassis. Burn marks from repeated arc overs are evindent (the arc
> that makes it fail is not the 1st time it occurs!)
> conductors and getting past the MOVs to build a potential on the
> boards.
> TJS
Put a humidifier inside the room, the air is too dry and static electricity
builds up.
ciao Ban
Apricale, Italy
T
Guest
Posts: n/a
      04-04-2006, 09:33 PM
This was th 1st thing we fixed. The RH was 15%, we raised it to 45% (its
winter). The adjacent control rrom is around 15% .
TJS
"Ban" <(E-Mail Removed)> wrote in message
news:ayBYf.15381$(E-Mail Removed)...
>> boards.
>> TJS
> electricity builds up.
> ciao Ban
> Apricale, Italy
petrus bitbyter
Guest
Posts: n/a
      04-04-2006, 09:43 PM
"T" <(E-Mail Removed)> schreef in bericht
news:Y-(E-Mail Removed)...
>plagued by computer power supply failures. The supplies fail when
>apparently many tens of thousands of volts jump from inside the PS around
>the switching regulators to the chassis of the supply taking out all the
>components. This has happened to 8 supplies so far. A visible blue flash
>has been witnessed several times by pewrsons in the room.
> happening. The computers are various brands and varoious ages, from 1 week
> old to 5 years old. The probelm began occuring 2 months ago. The data
> potential differnce is building. It jumps a 1 inch gap to the chassis.
> Burn marks from repeated arc overs are evindent (the arc that makes it
> and getting past the MOVs to build a potential on the boards.
> TJS
Is ground still connected to good old earth? You'll have to check to be
sure. Suppose the metal of the floor and installation has been grounded
carefully but you'll have to check this too. An open ground connection may
be the cause of you problems. Especially an open connection that is closed
again by someone entering the room.
On all PCs and servers I know, the secondary of the power supply has been
connected to the enclosure which in turn is grounded. So I assume the spark
jumps from the primary of the power supply the the chassis. Looks like
neutral and hot are floating which means that the neutral has not been
connected to ground, at least not properly. (Don't know where neutral should
be grounded in your place.)
There are other possibillities. Did someone install a badly insulated neon
sign near you? Some other renovation maybe? Something else I can't even
imagine but not very likely. I'm pretty sure something is not grounded
properly anymore, but what?
petrus bitbyter
john@jjdesigns.fsnet.co.uk
Guest
Posts: n/a
      04-05-2006, 12:27 AM
> TJS
A near identical situation was cured simply by spraying the carpet
tiles in the computer room and access corridor, with anti static
solution.
john
T
Guest
Posts: n/a
      04-05-2006, 01:41 AM
We have ordered some conductive matting for walking on. Waiting for it while
supplies are failing!
news:(E-Mail Removed) oups.com...
>> TJS
> solution.
> john
T
Guest
Posts: n/a
      04-05-2006, 01:44 AM
My technicians have been testing the grounds to the steel and they are
intact. We have a new fiber pull coming into the room just today via and
existing conduit. The failures have been occuring for almost 2 months but
much more frequently these last 2 weeks.
"petrus bitbyter" <(E-Mail Removed)> wrote in message
news:4432ea11$0$5636$(E-Mail Removed)4al l.nl...
> spark
> should
> petrus bitbyter
Michael A. Terrell
Guest
Posts: n/a
      04-05-2006, 02:06 AM
I would have the electrical system inspected. The power transformer
for the building may not be properly grounded. The ground rod or wiring
may be damaged, leaving the transformer floating above ground.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
TJS
Guest
Posts: n/a
      04-05-2006, 12:59 PM
An update; We are investigating "zinc whiskers" phenomina as a possible
cause. The zinc filaments are produced from the plywood core floor panels
supported by the zinc electrocoted support structure. When floor panels are
lifted or disturbed the conductive dust can get into the power supply and
lead to shorts between the modern closely spaced SMT devices.
See here for a white paper http://www.dataclean.com/pdf/zincwhiskers3.pdf
The failures/arcs in our supplies have all arced from the 120vac chopper
regulator collector to the PS case. If the zinc whisker problem is our case
then the blue flash is just a 120/170p-p vac arc to ground, and not a static
discharge.
We are looking at replacing our floor tiles with the modern ultra low static
floor tiles.
I'm a little skeptical that this is the problem, but it is true that 2
months ago we pulled floor tiles to look for fiber conduits and that about
the time the problems began
TJS
"T" <(E-Mail Removed)> wrote in message
plagued
This
happening.
> built 12 years ago.
the
regulator
differnce
repeated
> occurs!)
and
> TJS
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Power room close to server room SQLit Electrical Engineering 0 05-25-2006 02:04 AM
Re: Power room close to server room SQLit Electrical Engineering 1 05-24-2006 02:20 AM
Re: Power room close to server room gfretwell@aol.com Electrical Engineering 0 05-23-2006 04:28 PM
Computer room static blowing server power supplies T Electronic Repair 26 04-08-2006 02:13 AM
Computer room static blowing server power supplies T Electronic Equipment 21 04-08-2006 02:13 AM
