Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Is a computer fan an inductive load?
Reply
Thread Tools Display Modes
Jon Danniken
Guest
Posts: n/a
      11-20-2006, 11:49 PM
Howdy,
I am designing a circuit to switch on and off a computer fan with an NPN
transistor. I am wondering if I should use a diode across the computer fan,
to protect the transistor agains trainsients from switching (if the fan
behaves as an inductive load).
Thanks for any advice on this,
Jon
John Popelish
Guest
Posts: n/a
      11-21-2006, 12:03 AM
Jon Danniken wrote:
> Howdy,
Even if the fan contains a brushless commutation circuit. it
probably exhibits some inductive behavior at the supply
terminals. I would add the diode.
John Popelish
Guest
Posts: n/a
      11-21-2006, 12:08 AM
John Popelish wrote:
> Jon Danniken wrote:
>> Howdy,
>> computer fan,
> Even if the fan contains a brushless commutation circuit. it probably
> exhibits some inductive behavior at the supply terminals. I would add
> the diode.
Sorry, but on thinking about this a bit more, any brushless
driver will probably act as a diode across the motor, when
power is disconnected.
rebel
Guest
Posts: n/a
      11-21-2006, 12:43 AM
On Mon, 20 Nov 2006 16:49:45 -0800, "Jon Danniken"
<(E-Mail Removed)> wrote:
>Howdy,
Try watching the voltage on a CRO as you switch it off (with a switch) - if
there is an inductive kick it should be visible.
or use a diode anyway, to be sure to be sure. They're cheap.
Jon Danniken
Guest
Posts: n/a
      11-21-2006, 03:02 AM
"John Popelish" wrote;
> > Jon Danniken wrote:
> >> Howdy,
NPN
> >> computer fan,
> > the diode.
Thanks, John, and Rebel. I'll probably just add the diode just to on the
safe side.
Jon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triac and inductive load mkrnews@gmail.com Electronic Design 5 12-11-2008 02:34 PM
inductive or resistive load Cepowak Electronic Basics 5 12-12-2007 01:57 AM
Re: Is a pump a resistive or inductive load? Charles Misc Electronics 0 06-20-2007 08:26 PM
Resistive or inductive load and relay rating Nick Electronic Basics 3 04-10-2006 03:35 PM
Resistive load / Inductive Load ?? news Electronic Basics 6 11-23-2004 06:17 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
