One example of a 'behind the meter' surge protector:
http://www.leaintl.com/pdf/MsaCutsheet.pdf
They typically cost more money for less joules.
To combine other posts in this and so many other newsgroups
into one response: may be good reason why no one will supply
parts for your breaker box. The manufacturer is Federal
Pacific or FPE. Box may be the type that has a notoriously
history. Learn if your breaker box is that dangerous type as
demonstrated here:
http://www.inspect-ny.com/fpe/fpepanel.htm
You might consider first replacing the breaker box. This
would also upgrade the earthing that was not sufficient for
surge protection 25 years ago.
Robert11 wrote:
> Want to add a few circuit breakers to an existing box in a residence.
> Hate to pull one out to take to HD, and realize that there are
> many different physical sizes of these things.
> Was wondering if anyone might happen to know what circuit breaker
> models (single pole, 15 amp) will fit in a:
> LX112-24 by the Federal Pacific Electric Company
> who I understand is no longer in business. (true ?)
