Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Hobby Electronics > Come up with a brilliant solution .......
Reply
Thread Tools Display Modes
Geocacher
Guest
Posts: n/a
      09-22-2005, 12:02 PM
I work in the trailer manufacturing business.
We use LED tail-light clusters.
The modern truck/tractors utilise a computer system to perform diagnostics
on various systems within the rig. One of these is the lighting system.
A pulse is sent to each tail light, the system monitoring the current. If
there is current flow, it is assumed the incandescent globes are OK.
Unfortunately, the LED lamps draw such a small amount of current that the
computer does not see a "filament" and flags a major fault on the truck
dashboard. In addition to the error message, the system continues to send
curent pulss in the forlorn hope that things at the rear of the rig have
improved. This causes the entire suite of LED lamps to flash like a
low-class disco!
There are ways around it. Some manufacturers have placed incandescent globes
in parallel with the LED lamps, others have used high wattage resistors.
Neither is acceptable for obvious reasons.
There must be a way to "tell" the computer that the LED lamps are fine by
emulating the current drawn by an incandescent globe, without using the
solutions noted above.
Do any of you outstandingly brilliant contributors have any novel and
innovative ideas?????
budgie
Guest
Posts: n/a
      09-22-2005, 12:46 PM
>low-class disco!
The only ways I can see to "emulate" current draw is to either:
(a) actually draw it (resistor, incandescent bulb or similar, as you mention);
(b) modify the sense circuitry for greater sensitivity; or
(c) interpose a "box" that senses LED array current and fudges the pooter input.
If the current sense circuitry simply senses volt drop across a sense resistor,
you'll need to increase it. If it uses a transformer approach with an open
toroid, wind more turns on it. This assumes that the circuitry can be modified
(legality, access, information availability).
Nope, only basics.
Nicholas Sherlock
Guest
Posts: n/a
      09-22-2005, 07:36 PM
Does the manufacturer offer an updated ROM for your model?
Cheers,
Nicholas Sherlock
Geocacher
Guest
Posts: n/a
      09-22-2005, 08:51 PM
No. Manufacturers of the truck/tractors offer no assistance. They will not
permit any tinkering with their computer systems - will void the warranty -
and have not come up with any viable solution themselves!
"Nicholas Sherlock" <(E-Mail Removed)> wrote in message
news:dgv15u$b5j$(E-Mail Removed)...
> Cheers,
> Nicholas Sherlock
Franc Zabkar
Guest
Posts: n/a
      09-22-2005, 10:22 PM
On Thu, 22 Sep 2005 14:02:39 +0200, " Geocacher" <(E-Mail Removed)> put
finger to keyboard and composed:
>low-class disco!
You need some way of drawing the required amount of current for the
duration of the pulse, and zero amps thereafter. What about a simple
circuit based around a parallel PTC resistor, ie something like what
happens inside a TV set during automatic degaussing at switch-on?
-- Franc Zabkar
Please remove one 'i' from my address when replying by email.
Richard Waters
Guest
Posts: n/a
      09-22-2005, 11:23 PM
Franc Zabkar furiously typed the following on 23/09/2005 8:22 AM:
>>low-class disco!
> -- Franc Zabkar
What about a feedback amp?
Ken Taylor
Guest
Posts: n/a
      09-22-2005, 11:47 PM
"Franc Zabkar" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
>>low-class disco!
>>globes
> -- Franc Zabkar
That would work for the pulse but would it work when the light was switched
on (as in tail lights - the PTC would go high resistance and the computer
would no longer detect enough current)? I think just a parallel resistor is
going to be required. Certainly the least complexity solution. Or maybe,
dare I say it, the light bulb.....
Ken
Craig Hart
Guest
Posts: n/a
      09-23-2005, 12:01 AM
how about, you make a circuit that AC-couples (use a capacitor) the brake
line to a transistor that switches in a low impedance load (resistor) for a
short time (e.g. 50ms). each time the brake line pulses high, the pulse
turns on the transistor for a moment.
the constant "on" signal of the brakes won't trigger the circuit due to the
AC coupling.
such a short on-time won't effect brakelight performance any, but will be
long enough to allow the computer to 'sense' the higher load.
" Geocacher" <(E-Mail Removed)> wrote in message
news:dgu6hc$g0q$(E-Mail Removed)...
> low-class disco!
globes
Clifford Heath
Guest
Posts: n/a
      09-23-2005, 12:04 AM
Surely the obvious solution is an electrolytic capacitor with large
valued parallel discharge resister and smaller series resister. When
the current pulse is sent, the series resister determines the initial
current draw. The parallel resister enables the cap to discharge for
another cycle.
How big a capacitor you need is determined by the required current
draw and the amount of time after switch-on that the current is sensed.
The idea will only be feasible of the time is very short. Normal
V=I*C*T rule applies.
Clifford Heath.
Ross Marchant
Guest
Posts: n/a
      09-23-2005, 12:28 AM
> low-class disco!
globes
Is the current only checked during the pulse?
Ross
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
[OT] just brilliant... mrdarrett@gmail.com Electronic Design 9 11-21-2006 09:16 AM
Brilliant idea needed!!! Geocacher Electronic Design 40 09-28-2005 01:28 PM
Is this brilliant or bogus? Don Lancaster Electronic Design 11 08-10-2005 07:12 AM
Another Brilliant Rumination - Waterproofing LED Flashlight Projects Watson A.Name - Watt Sun, Dark Remover Electronic Design 19 12-01-2003 01:50 PM
Another Brilliant Rumination - Waterproofing LED Flashlight Projects Watson A.Name - Watt Sun, Dark Remover Misc Electronics 15 12-01-2003 01:50 PM
