If you don't want to solder and tape, you can also use a Marr connector of
the correct size as well. Make sure you twist all the red wires together
tightly after stripping off about 1 inch of the insulation, so the Marr
connector simply ensures a continuing tight joint, just as you would when
wiring AC. It also pays to double up the wires in the pigtail...ie two red
wires twisted together at each end going to the Aux + and two black wires
together in the Aux -.
I have installed over 1200 alarms for my own company, as well as others,
without a hint of a problem this way.
R.H.Campbell
Home Security Metal Products
Ottawa, Ontario, Canada
www.homemetal.com
"Robert L. Bass" <(E-Mail Removed)> wrote in message
news:aMudnX3JtIUKzabfRVn-(E-Mail Removed)...
>> I am currently wiring up a vista 20p system
>> and have run into a situation where I will
>> have brought 8-10 wires going to 1 screw
>> post for aux power. Does anyone have any
>> recommendations on a cleaner way to wire
>> this up so that the wires will not be so messy
>> to the single post?
> Bring all of the red (+) and black (-) wires together in two bundles. Add
> an extra pigtail lead to each bundle. Solder and tape the splices. Run
> the pigtails up to the AUX power terminals. This is the best technique.
> Regards,
> Robert L Bass
> Bass Home Electronics
> 2291 Pine View Circle
> Sarasota · Florida · 34231
> 877-722-8900 Sales & Tech Support
> http://www.bassburglaralarms.com
