Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > Circuit Diagram/ Block Diagram of IGBT tester
Reply
Thread Tools Display Modes
raju
Guest
Posts: n/a
      11-08-2003, 11:16 AM
I am a student of Electrical & Electronics Engg. I have been given
"IGBT Tester" as my final year project at SIEMENS. I needed some
information on how to exactly an IGBT is tested. It would be of great
help if anyone could explain me the working of an "IGBT tester"
preferably with a block diagram.
Frank Bemelman
Guest
Posts: n/a
      11-08-2003, 12:26 PM
"raju" <(E-Mail Removed)> schreef in bericht
news:(E-Mail Removed) m...
Depends on what you want to test. It could be as simple as a 9V battery,
a pushbutton, two resistors and a led.
I would start looking at various datasheets, see what looks as the
most interesting aspects of a IGBT, and then decide what needs to
be tested/measured/verified and estimate what can be done in the
time available for this project.
If you need inspiration, here's what seems a nice tester:
http://www.lemsys.com/FicheTRD2030-2.html
Frank Bemelman
(remove 'x' & .invalid when sending email)
Dr. Anton Squeegee
Guest
Posts: n/a
      11-08-2003, 09:51 PM
In article <(E-Mail Removed)> ,
(E-Mail Removed) says...
I don't know how they do education in India, but the usual process
in the States is that students are expected to do their own homework.
Dr. Anton Squeegee, Director, Dutch Surrealist Plumbing Institute
(Known to some as Bruce Lane, KC7GR)
kyrrin a/t bluefeathertech d-o=t c&o&m
Motorola Radio Programming & Service Available -
http://www.bluefeathertech.com/rf.html
"Quando Omni Flunkus Moritati" (Red Green)
Tim Auton
Guest
Posts: n/a
      11-08-2003, 10:13 PM
Without ever asking anybody for help? Do they even let you read books?
He said it was a final year project, he's going to have to do a whole
lot more work whatever help he gets here. A few usenet posts don't
make a final year project.
Tim
And the beast shall be made legion. Its numbers shall be increased a
thousand thousand fold. The din of a million keyboards like unto a great
storm shall cover the earth, and the followers of Mammon shall tremble.
- The Book of Mozilla, 3:31
Watson A.Name - Watt Sun, Dark Remover
Guest
Posts: n/a
      11-09-2003, 06:47 AM
In article <3facef0f$0$56510$(E-Mail Removed)>,
(E-Mail Removed)lid mentioned...
Yeah, but let's be fair. These IGBTs are usually heavy duty, high
current devices. A serious test is going to need a bit more current
than a 9V battery can supply. OTOH, if the pulse duty cycle is very
low, it might be possible. But the gate driving circuitry is probably
going to need more than a 9V battery.
Jeez, 3000V at 2000 A (cough-cough!) Requires 230VAC at 16A! Just
the shipping alone will cost a whole lotta money! Whew!
Like, here's a piece of equipment that takes more juice than the whole
average home uses. Nice to plan ahead to make sure you can afford the
electric bill. Remember those Startrek episodes where they had to
make a choice between weapons and life support? Cap'n says Fire! and
we hear the 'PLOINK!' in the background and all the lights go dim.
COOL! Just testing another IGBT..
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@ h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/e...s/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@ u@e@n@t@@
Fred Abse
Guest
Posts: n/a
      11-09-2003, 01:01 PM
On Sat, 08 Nov 2003 23:47:21 -0800, Watson A. Name - "Watt Sun, Dark
No big deal in Europe. ISTR 230V cookers are fused at either 25 or 30A.
British household ring circuits are fused at 30A.
OTOH, since it'll be used in an industrial environment, 400V 3-phase might
be more appropriate (Assuming Europe again)
Then there's duct tape ...
(Garrison Keillor)
(E-Mail Removed)
Winfield Hill
Guest
Posts: n/a
      11-09-2003, 01:11 PM
Watson A.Name - "Watt Sun, Dark Remover wrote...
> bemelmanx mentioned...
>> battery, a pushbutton, two resistors and a led.
Yes, an enjoyable scene to contemplate. But reality is a bit more
prosaic for these devices: banks of electrolytic capacitors charged
at leisure (230Vac at 16A is under 4kW - probably on the order of my
home HVAC), then operate at the rated voltage and current (6MW) for
a few milliseconds for the measurements. I made a 1.2kV 200A pulse
generator (0.25MW, 5ms) in a 7" relay-rack box, and it was half empty.
Although Lemsys' 6MW capability is 25x higher, it's not necessary for
Raju to get into that territory. He could make something on the same
size order as my box, big enough to test IGBTs up to TO-247 case size.
- Win
whill_at_picovolt-dot-com
Winfield Hill
Guest
Posts: n/a
      11-09-2003, 03:20 PM
Winfield Hill wrote...
Just an added thought. One must pick an reasonable scale and then be
satisfied with that. In the high-power engineering field someone,
someplace is always making, or already has made something bigger.
For example, consider the impressive 6MW rating of the Lemsys tester
mentioned above. Yet it's a real wimp, completely unable to handle
the 400MW capability of a single Dynix PT85QWx45 5" SCR puck (4.5kV
90kA peak), http://www.dynexsemi.com/products/pulse_power/index.htm
And if one were to design a tester capable handling the PT85QWx45,
then how about testing an array of these beasts, say as required for
a STATCOM (static reactive comnpensation) installation in a typical
utility transmission line? Should such a tester be devised, it'd be
completely unable to handle the serious testing requirements of DC
high-voltage transmission-line converters. So on and so forth.
Hmm, perhaps Raju can satisfy himself with testing small IGBTs, say
up to 600V 5A (130A max) parts; thaht's a more managable 80kW max.
There's quite a selection of cute little so-8 guys with this rating
intended for the huge flourescent ballast market, like Fairchild's
FGS15N40L, see http://www.fairchildsemi.com/pf/FG/FGS15N40L.html
- Win
CWatters
Guest
Posts: n/a
      11-09-2003, 08:33 PM
Try contacting an IGBT manufacturer. Ask if you can come and see them test
some IGBT. Tell them you are a keen student and they might even fund the
trip!
"raju" <(E-Mail Removed)> wrote in message
CWatters
Guest
Posts: n/a
      11-09-2003, 08:47 PM
"Dr. Anton Squeegee" <(E-Mail Removed)> wrote in message
news:MPG.1a171338a41e642f989ad6@192.168.42.131...
Oh you've got it all wrong. These days nobody can know everything and it's
more important to show you know where and how to get answers quickly than to
re-invent the wheel.
When I was in the air cadets (20 years ago) we stayed on an airbase for a
week. The staff decided to set us an exercise.... we had to make a map of
the base, then pretend we were terrorists and mark on it where we would
place 3 devices to best "take out the base". Not wishing to walk miles in
the rain our team went to the guard house and asked for a map. The person on
duty gave us a photocopy that showed just the outlines of the buildings and
not what was in them... so we told him we were "terrorists" and he helped
fill in the blanks and told us where to place our devices.... "Those three
blocks are the hangers" he said "..but only that one has any aircraft in
it". We were job done in 10 mins while the other groups got a soaking.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
block diagram showin 74LS138 being used with Z80 benbag2005 Electronic Basics 1 04-28-2005 05:02 PM
Re: Looking for an FFT block diagram for programming purposes Rich Grise Electronic Design 3 04-07-2004 04:32 AM
Re: Looking for an FFT block diagram for programming purposes Rich Grise Electronic Design 0 04-05-2004 03:24 AM
Circuit Diagram/ Block Diagram of IGBT tester raju Misc Electronics 8 11-12-2003 02:09 AM
Circuit Diagram/ Block Diagram of IGBT tester raju Electronic Design 11 11-12-2003 02:09 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
