Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Ceramic capacitors for higher voltage switchers
Reply
Thread Tools Display Modes
Joerg
Guest
Posts: n/a
      03-05-2010, 11:18 PM
Gents,
Anyone know what sort of ripple the FK22 series from TDK can take, say a
0.47uF/250V? I need some ceramics as output caps of a SEPIC that is
variable up to almost 100V, with some gusto (>50 watts). Can't use
electrolytics because of a harsh environment.
http://www.tdk.co.jp/tefe02/e4942_fk.pdf
Stacked SMTs are great but boutiquish and expensive. Anything
>0.47uF/>100V in thru-hole seems outlandishly pricey.
Regards, Joerg
http://www.analogconsultants.com/
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
Tim Williams
Guest
Posts: n/a
      03-06-2010, 05:58 AM
"Joerg" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
Well, take a guess at power dissipation and find the damping factor (X7R is
what, 1.5% or something?). If you're running hot, low power is probably a
good idea, like 1/8W or something. And use lots of copper (ha, like you
ever have the space).
So stack them horizontally instead? :-)
Or if you're cramped for horizontal space, maybe you could make a capacitor
daughterboard so they're stacked horizontally, on a vertical board...
Tim
Deep Friar: a very philosophical monk.
Website: http://webpages.charter.net/dawill/tmoranwms
Joerg
Guest
Posts: n/a
      03-06-2010, 02:04 PM
I wish they were physically a tad larger.
The client won't like that :-)
Regards, Joerg
Joerg
Guest
Posts: n/a
>>> say a 0.47uF/250V? I need some ceramics as output caps of a SEPIC
>>> that is variable up to almost 100V, with some gusto (>50 watts).
>>> Can't use electrolytics because of a harsh environment.
>> (X7R is what, 1.5% or something?). If you're running hot, low power
>> is probably a good idea, like 1/8W or something. And use lots of
>> copper (ha, like you ever have the space).
>> capacitor daughterboard so they're stacked horizontally, on a vertical
>> board...
>> Tim
> Just solder the caps in so they are on edge (vertical); one may be
> able to use 4 in parallel this way and use the same PCB board space.
Can't do that, it must remain machine-solderable.
Regards, Joerg
Archimedes' Lever
Guest
Posts: n/a
      03-06-2010, 06:30 PM
On Sat, 06 Mar 2010 01:55:35 -0800, Robert Baer <(E-Mail Removed)>
wrote:
> Can't use
Use hermetically sealed military versions then.
The difference in performance is worth the difference in price.
Archimedes' Lever
Guest
Posts: n/a
      03-06-2010, 06:34 PM
Pretty much very labor intensive assembly work. Not very good for any
automated process, so not good for anything that has intentions of large
volume production.
For short run, hand assembly though, no problem.
Vertical daughter cards are the way we did it in the HV lab.
50 Watts is a lot of loading for a ceramic cap bank to manage the
ripple of.
Joerg
Guest
Posts: n/a
      03-06-2010, 06:45 PM
> wrote:
>> Can't use
I know, and I do that. But it's often not easy to find some for higher
voltages with low enough ESR _and_ being available without huge leadtimes.
Regards, Joerg
Joerg
Guest
Posts: n/a
      03-06-2010, 10:38 PM
>> Gents,
>> Regards, Joerg
> Haven't used these particular caps but I have run some X7R 250V surfamce
> mount 2220 caps at 1A p-p ripple current at 10Khz. No
> noticable heating at all.
> A also run a 500V 2225 .47uF caps on the output of a 150V rail that can put
> out 75W (300Khz ripple) with no noticable heating.
I can't use these large SMT sizes in this case because of thermal stress
issues, cracks, and all that.
> You really have to hog some current on the ceramics to heat them up.
> That said I did have some x7r .1uF cap with teh yellow epoxy turn red when a
> 5A audio amp IC started oscillating into it. It was in an RC damper on the
> output. Scratched my head for a while trying to figure out why that cap
> got hot. I had thought before that ceramic caps were nearly ideal.
That's one reason why I asked. I've managed to turn capacitor ceramic
into bubbly green glass. But that was several MHz and several amps
through just one. The usual, had only one, did a quick experiment, "Come
on, hang on another 10 secs" ... *PHOOMP*
Regards, Joerg
Joerg
Guest
Posts: n/a
      03-06-2010, 11:51 PM
(E-Mail Removed) wrote:
> On Mar 5, 4:18 pm, Joerg <inva...@invalid.invalid> wrote:
>> Gents,
>> Regards, Joerg
> Rock | Joerg | Hard Place
The designs that get chucked over onto my desk are nearly always like
that :-)
Regards, Joerg
legg
Guest
Posts: n/a
      03-07-2010, 04:08 AM
On Fri, 05 Mar 2010 16:18:52 -0800, Joerg <(E-Mail Removed)>
wrote:
>Gents,
You can get capacitor characteristics from TDK.
http://www.tdk.co.jp/ccv/index.asp
The resistance, reactance and voltage/temperature dependencies are
illustrated graphically.
A 0.1uF 100V X7R part in 1206/3216 body size, 3216X7R2A104M, exhibits
an internal series resistance of 30mOhms, over the range of common
power conversion frequencies.
RL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
capacitors in series Ken O Electronic Basics 13 07-04-2006 03:38 PM
Ceramic capacitors Simon Smith Electronic Basics 3 06-14-2005 03:18 PM
FS: 2000: 50V 7.5pF Ceramic Capacitors :: $ 16 SHIPPED Jerry Rakar General Electronics 0 02-05-2004 10:52 PM
Re: smps design, A to Z, help. John Popelish Electronic Basics 14 08-10-2003 05:06 PM
embarrassing questions (long) Stephen Ramsay Electronic Basics 4 07-18-2003 02:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
