Walter Harley wrote:
> "ehsjr" <(E-Mail Removed)> wrote in message
> news:dTQMf.7608$UN1.4908@trndny08...
>> You guys may not be aware of how a carbon mike works.
>> You seem to think that the mike generates a voltage.
>> It doesn't. A voltage must be supplied to it. Sound
>> varies the pressure on the carbon, which causes its
>> resistance to vary. That causes the current through
>> the mike to vary.
>> What is the typical signal amplitude of a carbon mike?
>> Meaningless question. A carbon mike is not a source.
>> Without knowing the source voltage one cannot say what
>> the amplitude will be. Likewise, without knowing the load
>> impedance, one cannot say what the amplitude will be.
>> The signal (and by that I assume you mean the voltage
>> drop across the mike) is a result of the current through
>> the resistance of the carbon. That current depends on
>> source voltage and load impedance, as well as mike
>> impedance at a given audio level & frequency.
> Ed, the OP asked about how much AC voltage is generated across the
> mic if he runs a DC current through it and presents it with an
> acoustic signal. Since a carbon mic behaves like a variable
> resistor, that is an entirely meaningful question: if a DC current is
> applied to a variable resistor, the voltage across the resistor will
> vary. The unanswered part is "how variable is the resistor"? Does
> it vary by 1% before clippping, or 10%, or what? Does the resistance
> increase, or decrease, or both, compared to nominal?
> Or, you could answer a different question, that still could
> reasonably be presumed to be helpful: what sort of circuit might one
> typically and usefully employ, to develop an electrical signal from a
> carbon mic?
> Dan Akers suggested that there's just no way to know. But I suspect
> that knowing the answer for "some" specific carbon mic would be more
> helpful than knowing nothing at all - even if it's an order of
> magnitude away from this one, it's a starting point.
A carbon capsule is likely to be big and went after the advent of electret
mikes into the garbage bin and no sane person will use this technology for
other then close voice pickup and drving a horn speaker directly though a
12V battery, a megaphone without amp. When the OP measured some resistance,
it doesn't mean it is only resistive, but might be an Electret mike which
have about 0.5mA bias current and might on a multimeter show up as some
obscure value.
If the OP would also measure with the test leads crossed the same resistance
it is certainly not an electret mike, exept those with 3 pins where there is
a resistor between supply and output.
ciao Ban
Apricale, Italy
