Thanks All
I'm in Bibra Lake Western Australia. Looking through the grill
for the oven light I can see a box shaped object about 40mm X
40m X 90mm which I assume is the transformer (there is also
evidence of matching mounting bolts on the bottom of the oven in
this area) . Unfortunately (or I guess for safety sakes,
fortunately) it and everything else there appears covered by
foil so without opening it up I can't confirm it's the
transformer or ID the type. Opening it will doubtless void my
warranty.
After comparing notes with the rest of the family, who more
frequently use this combination oven, I can add the following
observations:
a) It started crackling a few weeks ago with the onset of
hotter summer weather;
b) When it happens there is also a lot of condensation present
inside the oven (cooking area);
c) It stopped yesterday with a thunderstorm bringing cooler
temperatures - the condensation in the oven also disappeared at
the same time.
I can't help wondering if condensation is getting inside the
area where the transformer is and causing it or the mains
connections to short and arc. I assume this area should be
sealed off from the cooking compartment. I suspect this seal
has failed and moisture from cooking is getting into this area
or alternatively from outside the oven. Note my house is air
conditioned with ducted evaporative air conditioning - perhaps
that contributes to the formation of condensation. The oven is a
combination microwave, convection & grill.
Regards
Blue
Remove ZX from email address to reply directly.
