Electronics Forums
Electronics Forums > Electronics Forums > Electronics Homework Help > How can i fix fan in my new home
Reply
Thread Tools Display Modes
Junior Member
      02-02-2012, 09:10 AM
Hi, That we build a new home for that we need fan,I got USHA fan but i don't know to connect in roof anyone can help?
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      02-02-2012, 09:23 AM
I typically use an electrician.
Junior Member
      02-06-2012, 10:25 AM
Hi, I attach the fan with roof, But i want to know what wire want to give phase and what wire that goes to neutral..
Senior Member
      02-06-2012, 01:44 PM
Quote:
In the states, the black is supposed to be the 'hot'. But this can get a bit tricky if someone has wired in a switch, etc. So it is best to test the wires with a MM, with the electric on.
Junior Member
      03-14-2012, 11:00 AM
you must consult an electrician for this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trying to fix home subwoofer amplifier. Any help is appreciated. jener8tionx Electronics Repair 24 06-13-2013 04:04 PM
Dehumidifier not working - suspect fault in fan motor; easy fix? seanspotatobusiness Electronics Repair 9 09-17-2012 01:02 AM
Motor Fan - Not Fan Motor - Sigh! Bob La Londe Electrical Engineering 7 01-12-2012 10:06 PM
Home made fix to charging problems? shedabosss@gmail.com Electronic Repair 3 05-18-2007 11:14 PM
Do you think NI can fix my PLL? Chris Carlen Electronic Design 72 07-12-2006 03:00 AM
