Robert Baer wrote:
> Michael Noone wrote:
>> Hi - I'm looking at this page: http://www.proav.de/data/wire-
>> resistance.html - and am trying to figure out the thinnest guage wire
>> I can use. Is there a good rule of thumb for this? I was thinking
>> about using some 28 AWG wire (as I would like to use some .05" pitch
>> ribbon cable). According to that page it's 232ohm/km. I need it to go
>> about 15cm, so (232/1000)*.15 = .0348ohms. I'd like it to be able to
>> handle 1.5A max current (though I'd be incredibly surprised if current
>> spiked above 1A, and normally it should be under 200ma. So, .0348 *
>> 1.5 = 0.0522V drop at peak current. Supply voltage is 6V, so .0522/6 =
>> 0.87% of power (.0783W) dropped over the wire. Is this OK? Or is this
>> pushing things? Am I reading the table correctly and are my
>> calculations correct?
>> Thanks!
>> -MJ Noone
> This is the rule of thumb that i have used to wind power transformers,
> and i have never had any IR problems: Start with the maximum current, in
> milliamperes for the wire in question. and look in a wire chart for the
> size with the closest value cross-sectional area in circular mils.
> Example: number 30 wire would be rated for use near 100mA maximum
> current (continuous).
> That same wire seems to be useable asa replacement for a one amp fuse.
> If that follows your tests, then the "fuse rating" would be roughly
> ten times my rule of thumb rating.
#define circular mil dimensional madness
ROT are a terrible way to design anything. As is current density (even
more so when expressed in amps per circular mil). All that matters is
temperature rise. Continuous current rating is invariably specified with
an isolated wire in optimal thermal conditions; winding a whole bunch of
terns in close proximity (if the feathers dont interfere) changes things
significantly. See, for example, the various articles written in the
[cant recall name] PCB design comic, or standards for PCB current
density, where N adjacent identical tracks are considered the same as
one track of N* width carrying N* current, due entirely to thermal coupling.
why not assume adiabatic heating to work out fusing current? the maths
is trivial. Again, well covered in PCB design comics.
If the insulation is PVC, and you heat it up, it will outgass chlorine,
which aint too good for crimped connections.
Cheers
Terry
