On Thu, 21 Jan 2010 12:43:20 -0500, Rich Webb
<(E-Mail Removed)> wrote:
>On Thu, 21 Jan 2010 16:35:55 +0000, Raveninghorde
><raveninghorde@invalid> wrote:
>>On Thu, 21 Jan 2010 07:33:02 -0800, John Larkin
>>>On Thu, 21 Jan 2010 15:06:10 +0000, Raveninghorde
>>>>How do you calculate MTBF?
>>>Get the failure rate of each part (specified in FITS, failures per
>>>billion hours), add them up, take the reciprocal, multiply by a
>>>billion.
>>>John
>>Thanks
>>The National site is good and I found the info for the their parts.
>>Microchip no luck, IR no luck. So where do you normally find the
>>information?
>>I suppose one also assumes perfect ESD procedures, and perfect lead
>>free soldering.
>You're new at this so, even if you're not doing a MIL-STD prediction,
>I'd strongly recommend downloading MIL-HDBK-217 from the online site
><https://assist.daps.dla.mil/quicksearch/> (search on MIL-HDBK-217 in
>the Document ID field) and skimming though sections 3 and 4. The
>Bellcore process is similar.
>John's basic equation is correct. You can use the tables in 217 to
>estimate the reliability of items for which the manufacturer does not
>provide the info.
>There are provisions to consider connections (e.g., "Quantity of Hand
>Soldered PTHs [plated through holes]"). It's a hell of a lot of work to
>do a full analysis.
Given the customer I'll go with 217. I'm trying to avoid spending a
week doing this so I'm looking at other solutions.
I've seen a few websites that offer online calculation ($500) or send
the BOM and results in 48 hours ($1500). I've also seen some programs
that calculate MTBF.
Anyone tried these options?
