Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Security Alarms > Caddx NX-148E Problems
Reply
Thread Tools Display Modes
Phil
Guest
Posts: n/a
      01-17-2005, 10:42 PM
I have a Caddx NX-8 control panel with a NX-216 zone expander and 4
NX-148E keypads that was installed about 18 months ago by a relative
who did have his own alarm business. This relative was killed in a car
wreck shortly after installing my system so I have no one to turn to.
The problem is that last night the keypads just started beeping. The
fire light on the keypads started blinking and the siren did go off. I
entered *7 but this did not do anything. I put in my user code and it
did silence it for a couple of minutes but eventually the siren went
off again. I ended up unplugging the control panel and battery.
Service required type *2 for help did appear on the keypad. When I
checked this I had two errors:
Expansion Box Tamper
Expasion Trouble
Any ideas? I should also add that it did do the same thing about 17
months ago but it only did it once and then it stopped until now.
Phil
Mark Leuck
Guest
Posts: n/a
      01-17-2005, 10:59 PM
Sounds like you have a problem with a smoke detector
"Phil" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> Expasion Trouble
> Phil
Phil
Guest
Posts: n/a
      01-18-2005, 12:05 AM
What would be the easiest way to determine this? How long will all my
programming stay in memory since the system and battery is unplugged?
relative
car
to.
The
off. I
it
went
> > Expasion Trouble
17
> > Phil
Phil
Guest
Posts: n/a
      01-18-2005, 12:35 AM
Maybe it is a smoke detector problem? My smoke detectors are ESL
429CST. I found one web page that says this detector is not compatible
with Caddx control panels. Is this true? How can I bypass the smoke
detectors to see if my system will work?
car
I
it
> Expasion Trouble
> Phil
alarman
Guest
Posts: n/a
      01-18-2005, 12:38 AM
Are ther smoke detectors connected to the system? If so what brand and how
many? Do any of them have a red led that stays on?
> Expasion Trouble
Before or after your alarm occurred?
js
observer
Guest
Posts: n/a
those detectors are OK.
take the 2 wires off zone 8 and the common terminal next to it and replace
them with a 680 ohm resistor. that will remove them from the system. then
you can power up and see if the problem has gone away.
alarman
Guest
Posts: n/a
      01-18-2005, 12:40 AM
Your programming will remain indefinitely.
js
alarman
Guest
Posts: n/a
      01-18-2005, 02:27 AM
The ESL429CST is not listed for use with the NX8. You need to replace them
with a model compatible with that panel like an ESL 429AT, 521 or System
Sensor 2WT-B. These do not have integral sounders like the 429CST however.
js
Paul
Guest
Posts: n/a
      01-18-2005, 08:37 AM
Might not be a smoke detector problem. When NX panels get zapped by
lightning or get a power surge the fire light rapidly flashes rapildy. So
could be quite serious.
Try powering the panel down and back up again. Sometimes this works
Paul
"alarman" <(E-Mail Removed)> wrote in message
news:uRYGd.3847$hu.1421@fed1read01...
>> Expasion Trouble
> js
observer
Guest
Posts: n/a
      01-18-2005, 12:45 PM
news:Sr_Gd.3861$hu.3394@fed1read01...
> js
I was thinking they were the ones with the integral heat. My bad.
The bypass instructions I gave should still work, though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Caddx NX-8E problems- newbie Glen Griffin Security Alarms 4 11-12-2010 04:08 PM
Re: caddx ranger 7600 Mark Leuck Security Alarms 0 07-20-2003 07:08 PM
Re: caddx ranger 7600 J. Stevens Security Alarms 0 07-20-2003 07:05 PM
Caddx NX-8 Outputs Security Alarms 7 07-17-2003 10:54 PM
Re: ITI and Caddx Frank Olson Security Alarms 0 07-08-2003 05:38 AM
