Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Misc Electronics > where to buy soft iron rods
Reply
Thread Tools Display Modes
Ken Williams
Guest
Posts: n/a
      06-28-2009, 07:52 AM
anyone know where I can buy soft iron rods in various sizes and shapes?
Seems to be a nightmare to find anything.
thanks.
Jasen Betts
Guest
Posts: n/a
      06-28-2009, 12:06 PM
these days a good substitute is mild steel.
I'd try a hardware outlet, if they dodn't have what I wanted I'd go to
a metal supplier like "metalcorp"
steel tie wires are mild steel, fencing wire is not
many bolts are mild steel.
> thanks.
Don Stauffer
Guest
Posts: n/a
      06-28-2009, 01:37 PM
> thanks.
I used to cut lengths of wire from coat hangers and bundle them to make
a soft iron core.
Ken Williams
Guest
Posts: n/a
      06-29-2009, 08:30 AM
>> thanks.
> news:rec.crafts.metalworking is where you want to ask. You don't say
> where you are located, whch makes a huge difference of where you can
> find it.
I'm in canada. ebay doesn't seem to have much when I search for "soft
iron core".
Ken Williams
Guest
Posts: n/a
      06-30-2009, 01:57 AM
Mark Rand wrote:
>> iron core".
> Sounds as if you are actually looking for magnetically soft iron rather than
> mechanically soft iron (they are fairly closely related, but not an exact
> match).
> If it's for an AC application, take a hacksaw to a microwave oven transformer.
> If it's a DC application, look for hot rolled, low carbon steel. probably
> AISI 1005 will be as good as you can get. High silicon magnetic steels tend to
> be fairly hard to obtain in small quantities and expensive except by robbing
> existing equipment (like MOTranfromers).
What about pulsed DC? thats considered AC?
Its for electromagnet coils that will be pulsed with DC. I want a good
iron core to concentrate the magnetic flux.
Steve R.
Guest
Posts: n/a
      06-30-2009, 06:26 AM
"Ken Williams" <(E-Mail Removed)> wrote in message
news:Mpd2m.1025$(E-Mail Removed)...
>>> iron core".
>> than
>> match).
>> transformer.
>> tend to
>> robbing
Tehn you need mu metal. Hard as hell to find!
Steve R.
alchazz
Guest
Posts: n/a
      06-30-2009, 02:26 PM
>>iron core".
> than mechanically soft iron (they are fairly closely related, but not an
> exact match).
> transformer. If it's a DC application, look for hot rolled, low carbon
> steel. probably AISI 1005 will be as good as you can get. High silicon
> magnetic steels tend to be fairly hard to obtain in small quantities and
> expensive except by robbing existing equipment (like MOTranfromers).
> Mark Rand
> RTFM
Coat hanger wire is made out of soft iron. Cut to length and pack into a
cardboard ( or whatever ) tube and wind your coil on that.
You should be able to find a lot of them. They seem to multiply in
closets. ;-)
Al
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Driving ground rods 0_Qed Electrical Engineering 5 04-04-2006 05:49 PM
Soft iron in the house? Little White Mouse Electronic Equipment 3 03-17-2006 05:15 PM
Electrical connections to carbon rods - how? Bill Bailley Electronic Design 11 07-06-2004 04:58 AM
Sinking Earth Rods Mark Electrical Engineering 13 02-11-2004 12:24 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
