Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Components > Butterworth bandpass filter question
Reply
Thread Tools Display Modes
TRABEM
Guest
Posts: n/a
      09-11-2005, 04:14 PM
I am trying to scale an existing front end receiver (butterworth
bandpass) filter to a different frequency range. Unfortunately, it has
a transformer in the original design, so I'm stuck. I also don't know
how to handle the load presented by the active front end component
other than it's probably not significantly reactive.
The existing filter is for a 7 Mhz receiver, I'd like to have a
similar filter design for 50 to 200 Khz.
The filter components and transformer winding details are in the
document at:
http://www.amqrp.org/kits/softrock40...0Assy%20v1.pdf
The input chip is an FST3126, spec sheet is at:
http://www.fairchildsemi.com/ds/FS/FST3126.pdf
The spec for the T30-2 transformer core is at:
http://partsandkits.com/T30-2.htm
I have aade filter design software, but it isn't allowing me to plug
in the transformer into the design page of the software....so, I need
to know it's equivalent circuit I think.
The transformer winding details are on page 4 of the document and the
schematic of the front end is page 9. Ultimately, I need new values
for L1, L2, C20, C21 and C22.
If someone can give me a reasonable guess as to the equivalent circuit
of the transformer and the IC (U5), I can do the rest of the job
myself using the aade filter software.
T
maxfoo
Guest
Posts: n/a
      09-11-2005, 05:09 PM
On Sun, 11 Sep 2005 12:14:11 -0400, TRABEM <> wrote:
Get the free software program call RFsim99 lets you design buttrworth filters.
Reg Edwards
Guest
Posts: n/a
      09-12-2005, 06:07 AM
How do you know it is a Butterworth as distinct from other types?
TRABEM
Guest
Posts: n/a
      09-12-2005, 04:18 PM
A butterworth is a butterworth............in any discussion of the
butterworth filter, you will see this schematic.
Asking how I know it's a butterworth is a little like asking how I
know a car is a car.
However, I don't know it all.........perhaps it's closely related to a
butterworth, but called something else???
Let me know if I've made an error please.
T
On Mon, 12 Sep 2005 06:07:31 +0000 (UTC), "Reg Edwards"
Helmut Sennewald
Guest
Posts: n/a
      09-12-2005, 04:49 PM
<TRABEM> schrieb im Newsbeitrag
news(E-Mail Removed)...
> T
Hello T,
a Bessel filter would have the same structure. The value of
the components define what filter type it is.
Bessel: max. flat group delay
Butterworth: max flat frequency response
You can also make a filter with this structure which is anything
between both types.
Best regards,
Helmut
TRABEM
Guest
Posts: n/a
      09-12-2005, 08:57 PM
Cool, didn't know that.
At VLF, the inductances are becoming quite large, requiring a toroid
core for even a simple inductor.
What are the advantages/disadvantages of each type relative to
inductor size requirements?
Maybe I should be looking at a bessel instead of a butterworth.......
GL to all.
T
maxfoo
Guest
Posts: n/a
      09-13-2005, 07:33 AM
>T
A Butterworth filter is a Chebyshev filter with No ripple in the passband.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Butterworth bandpass filter question TRABEM Electronic Repair 7 09-29-2005 03:51 PM
Butterworth bandpass filter question TRABEM Electronic Design 7 09-13-2005 07:33 AM
Butterworth Filter dhruveenews@gmail.com Electronic Design 13 06-26-2005 12:21 AM
Butterworth filter Chaipa Beginner Electronics 0 04-27-2004 06:15 PM
Re: Inventor of butterworth filter CWatters Misc Electronics 1 04-05-2004 12:15 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
