Electronics Forums
Electronics Forums > Electronics Forums > Project Logs > Buck converter for small wind turbine project
Reply
Thread Tools Display Modes
Junior Member
      01-10-2012, 10:36 AM
Greetings, I am new to the forum. I recently constructed and tested a working PMA and VAWT. At 40 MPH it will produce 9 amps DC using a 12 volt deep cell for a test load.
I recently watched a video of a MPPT controller.
http://www.youtube.com/watch?v=0TE38...layer_embedded
This is a video that demonstrates the benefits of using a MPPT circuit with a PMA.
I started a project for a very basic buck converter to determine if it will produce a higher output from my PMA at a lower wind speed.
As I understand the circuit chargers the output inductor when the MOSFET is on.
When the MOSFET is off, the turbine will be allowed to maintain a higher RPM and the energy stored in the inductor will discharge current into the battery.
The output voltage will always be fixed to the battery voltage.
The input voltage will change as the turbine RPM changes.
The input voltage will be high with low current and the output voltage will be low with higher current because the energy stored in the large output inductor will discharge into the battery as the MOSFET turns on and off.
I have all the parts to fabricate a very basic low amp output buck converter.
I am trying to design the basic test circuit so a micro controller can be added if required.
This is a first attempt at designing a power circuit. I have a basic understanding of all the concepts involved and comments are welcome.
Buck converter for small wind turbine project-1.jpg   Buck converter for small wind turbine project-a1.jpg   Buck converter for small wind turbine project-side.jpg   Buck converter for small wind turbine project-connectors.jpg   Buck converter for small wind turbine project-buckbasictestcircuit.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wind Turbine power source/possible water turbine Dewisa Electronic Projects 1 04-11-2013 12:21 AM
Buck converter for small wind turbine project Harald Kapp Project Log Discussion 17 04-08-2012 09:13 AM
Re: Transmission of Power From Small Wind Turbine melon Electrical Engineering 0 05-10-2004 02:04 AM
Re: Transmission of Power From Small Wind Turbine bushbadee Electrical Engineering 1 05-08-2004 12:52 AM
Re: Transmission of Power From Small Wind Turbine repatch Electrical Engineering 0 05-06-2004 02:32 PM
