I am working on a project to replace some bad caps in my TV. While removing one of the caps, the lead broke in the pcb. I tried to get it out by:
- Adding more solder to try and liqufy what was left in the hole
- Heating and pushing\pulling
Ultimately, the lead is now to the point where it is flush with the pcb, and I can't get the solder to melt enough to push it through. The back side has been overheated...hopefully it looks worse in the picture than it really is.
Is it possible to just clip the lead of the new replacement capacitor to length, and solder it to what is left in the hole? I will have to of couse secure so it doesn't break in the future.
I could drill it out, but I'm not sure on how to repair the hole if it gets worse. The cap is a 470u 35v.
Thanks in advance for any advice.
