On Thu, 22 Sep 2005 14:02:56 +0200, " Geocacher" <(E-Mail Removed)> wrote:
>I work in the trailer manufacturing business.
>We use LED tail-light clusters.
>The modern truck/tractors utilise a computer system to perform diagnostics
>on various systems within the rig. One of these is the lighting system.
>A pulse is sent to each tail light, the system monitoring the current. If
>there is current flow, it is assumed the incandescent globes are OK.
>Unfortunately, the LED lamps draw such a small amount of current that the
>computer does not see a "filament" and flags a major fault on the truck
>dashboard. In addition to the error message, the system continues to send
>curent pulss in the forlorn hope that things at the rear of the rig have
>improved. This causes the entire suite of LED lamps to flash like a
>low-class disco!
>There are ways around it. Some manufacturers have placed incandescent globes
>in parallel with the LED lamps, others have used high wattage resistors.
>Neither is acceptable for obvious reasons.
>There must be a way to "tell" the computer that the LED lamps are fine by
>emulating the current drawn by an incandescent globe, without using the
>solutions noted above.
>Do any of you outstandingly brilliant contributors have any novel and
>innovative ideas?????
The computer doesn't send the pulse, it instructs the "system" to send
the pulse and measure the response.
Change your algorithm, so the response is meaningful... maybe trickle
100uA and measure the voltage... LED's ARE junction devices, you know?
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice
480)460-2350 | |
| E-mail Address at Website Fax
480)460-2142 | Brass Rat |
http://www.analog-innovations.com | 1962 |
I love to cook with wine. Sometimes I even put it in the food.
