Electronics Forums
Electronics Forums > Electronics Forums > Datasheets, Schematics, Manuals and Parts > Bose Wave Radio/CD problem
Reply
Thread Tools Display Modes
Junior Member
      11-15-2010, 06:04 AM
I acquired a Bose Wave Radio/CD AWRC1G that was plugged into a improper power source
and blew out one or more components and does not operate when it it plugged in and the power switch is turned on. I checked and found that the fuse is not blown. All I want is to
find out how I can acquire a schematic diagram for this model. Thank you.
Senior Member
barathbushan's Avatar
      11-15-2010, 06:01 PM
hi larry ,
what do you mean by an improper source , improper voltage or frequency ???
if the fuse is not blown , it only means that a high current has not passed through the fuse
and nothing else
my guess is most probably a transformer failure
if nothing switches on , not even an led , then i have guessed right .
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      11-16-2010, 12:27 AM
My guess is that your guess is a very bold one, however the question you asked ("what do you mean by an improper source , improper voltage or frequency?") is certainly reasonable.
Googling the device in question, I can only imagine it was a 110V unit connected to 220V?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bose Wave Rado AWR1W1 touch pad problem papaG Electronic Repair 1 02-06-2013 01:18 PM
Bose Aucostic WAVE Jim McQueen Electronic Repair 0 12-27-2004 02:51 PM
Bose wave problem E. Oulashin Electronic Repair 3 04-21-2004 09:11 AM
