Electronics Forums
Electronics Forums > Electronics Forums > General Electronics Chat > Basic random generator
Reply
Thread Tools Display Modes
Junior Member
      01-31-2012, 09:33 PM
Hi all,
I was wondering if it was possible to create a (very) basic random number generator without the use of any IC (Display could be something as simple as some LEDs, an IC controller for the display is fine), and if anyone has a link to a circuit diagram for one?
Regards
Max
Senior Member
      01-31-2012, 10:00 PM
Are you talking about a true random number generator or a pseudo random number generator, they are two entirely different things.
Senior Member
Raven Luni's Avatar
      01-31-2012, 10:35 PM
If you only need a low number you can use an astable multivibrator or transistor chaser circuit that you can interrupt.
For more than that you would need more complex counters (ICs) or a way to quantise a thermal noise source.
0 OK, 0:1
Junior Member
      01-31-2012, 11:55 PM
Quote:
Doesn't have to be "true" random (Is there such a thing? ... no, just "very good random" I don't want that, I want pretty lights that look random lol.) just an extremely basic random "number" generator, let's say... 50/50 (on/off)... can it be done and display it in some way (LEDs?) without any kind of IC.
I know I could easily build one with an IC, I just want to build a small veroboard example with NO ic, that has a red and green light, with no discernible pattern, 50/50 is ideal, but, anywhere near that (40/60, 30/70) is acceptable.
EG: a red led and a green led, 50/50... pseudo random is fine, as long as there isn't a predefined set (Although I doubt a defined set would be possible without an IC anyway, and if it is... a very long set would do too.. say a predefined set of reds/greens 500 long [but again.. I can't see that without an IC being involved]).
Low number... 1 and 0... do you have an example?
Edit: Raven, thermodynamics kinda sucks, although I've been reading about oddities in various experiments which seem to at least in part, defy the second law...
Edit2: It's an interesting one, it's to win a (non monetary) bet, I will post results if successful, including a shot of the build and a gutted engineer....
Edit3: something like this: http://www.qrp.pops.net/LEDs.asp (Sequentially Off LED Pulser) 3 leds, somehow keeping the power on (so it runs) and showing ONE led when a button is pressed..... lol I don't know, I'm clutching at straws...
Senior Member
Raven Luni's Avatar
      02-01-2012, 12:47 AM
So its a coin toss thingy - heres a decent example: http://talkingelectronics.com/projec...TrCcts.html#30
0 OK, 0:1
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection) ...and don't call me Sir!
      02-01-2012, 01:38 AM
For a heads/tail type of circuit, the easiest way is to toggle your output at high frequency and manually interrupt the signal which causes the toggling.
If the signal to generate the random state itself comes from a process which generates it automatically, then your source of randomness almost certainly needs to be better than a simple high frequency oscillator (which will provide regular timing, so a regular sampling may yield predictable results). In this case a noise source (e.g. a reverse biased diode junction) may be preferable.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Simple random number hardware generator using low voltage 3.3V levels Nicholas Kinar Electronic Design 13 07-16-2009 09:04 PM
suggest basic func/signal generator for basic scope test/setup ? robb Electronic Basics 10 10-24-2007 10:53 AM
suggest basic func/signal generator for basic scope test/setup ? robb Electronic Equipment 10 10-24-2007 10:53 AM
Hardware True Random Number Generator design / concept Yoy G0 Electronic Design 20 06-24-2005 07:48 AM
Can you help with a simple generator for a random series of bits? Colin Howarth Electronic Design 26 11-16-2004 03:52 AM
