Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Baking parts sometimes necessary?
Reply
Thread Tools Display Modes
John
Guest
Posts: n/a
      01-04-2008, 11:43 PM
I ordered a couple of samples from TI and was surprised to find one
bag of the parts in a moisture-barrier bag with a "Bake prior to vapor
or IR soldering to reduce the chances of damage" warning label. The
other, seemingly similar, part came in a standard anti-static bag.
REF5040AID - in vapor barrier antistatic bag
REF5020AID - in standard antistatic bag
These parts, IMHO, are pretty darn similar considering that only the
voltage is different. Is there any special reason one was tagged as
needing baking and the other wasn't?
I checked the TI web site for moisture-sensitivity info and the
"rating" for both parts was the same:
REF5020AID MSL Level-2-260C-1 YEAR
REF5040AID MSL Level-2-260C-1 YEAR
From the TI site: "MSL (Moisture Sensitivity Level): is a JEDEC
industry standard classification that defines the length of time
products can be safely exposed to the ambient environment prior to
high-temperature reflow soldering."
It appears that they are both as sensitive (or not) to moisture, so
I'm a bit confused as to why the REF4040AID part was vapor-barrier
bagged. Not really important?
Thanks for any help you can give me,
John
John
Guest
Posts: n/a
      01-05-2008, 12:56 AM
Just to be clear, there's no way I'm baking any components before
using them. :-)
I was just wondering why similar components might be marked different
ways. I'll order different parts if I find that any really require
baking just for playing-around and low-volume device manufacture....no
mil or high-rel applications here.
John
Tim Wescott
Guest
Posts: n/a
      01-05-2008, 03:19 AM
On Fri, 04 Jan 2008 19:43:41 -0500, John wrote:
> I ordered a couple of samples from TI and was surprised to find one bag
> of the parts in a moisture-barrier bag with a "Bake prior to vapor or IR
> soldering to reduce the chances of damage" warning label. The other,
> REF5040AID - in vapor barrier antistatic bag REF5020AID - in standard
> antistatic bag
> I checked the TI web site for moisture-sensitivity info and the "rating"
> From the TI site: "MSL (Moisture Sensitivity Level): is a JEDEC industry
> standard classification that defines the length of time products can be
> safely exposed to the ambient environment prior to high-temperature
> reflow soldering."
> It appears that they are both as sensitive (or not) to moisture, so I'm
> a bit confused as to why the REF4040AID part was vapor-barrier bagged.
> John
At sample quantities it's quite possible that someone was careless about
putting the tag on the bag. If you're not reflowing them they probably
don't need to be baked -- if you _are_ going to reflow them, think of
popcorn.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
John
Guest
Posts: n/a
      01-06-2008, 09:37 AM
>>>popcorn.
Yea, you're probably right.
I do like popcorn though. :-)
John
Senior Member
      01-06-2008, 09:57 PM
both packaging offer protection of lsd so it is up to the manufacture what he think is best for them and lets not forget economy. question if foam better then foil no they both offer protection .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
articles : Parts Train Expands Facility to serve your Auto Parts needs hitsoption@gmail.com Electronic Basics 0 06-16-2007 12:53 PM
FA: Sharp microwave oven parts (good used parts) William E Miller Electronic Repair 0 03-14-2007 09:10 PM
Question for baking chips linnix Electronic Design 9 02-05-2006 10:41 AM
TV REPAIR CRTS, PCBS, PARTS, NEW UNUSED PARTS FOR SALE, MAKE US A OFFER, WE CAN SHIP WITH-IN 24 HOURS User Electronic Repair 7 12-19-2005 02:31 PM
Baking ICs? Rewar Electronic Design 13 02-01-2004 05:23 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
