I have looked into triac control of the primary, again controlled via opto-diac with pwm. but again theres very little info out there. all references ive found with "dimmer" type circuits require the switching to follow the input sine wave, not from an external signal source
As to power requirements, realistically 6-30v more most applications with as much current as possible, 10-110v on the odd occasion with lower currents required.
Its basically a power supply for electroplating, my wife and my self are keen amateurs bordering semi professional when the need arises . most things are done in the lower voltage range but require the high current. my wife would like to experiment with titanium colouring which requires the higher voltages.
Smoothing of the output can be as crude and unfiltered as you like.
I didnt expect this to be easy, but didnt expect it to be this difficult either.
so maybe a re-think. I have 6 of these transformers, so lets just concentrate on the 6-30v spectum. the higher voltage will be simple with just a variac type of control. cc/cv isnt required at that end of the scale so i would make more sense to make 2 separate supplies.
