On Fri, 10 Aug 2007 17:49:26 -0700, John Larkin
<(E-Mail Removed)> wrote:
>On Fri, 10 Aug 2007 18:53:31 -0400, John
>>I'll be using TO-247 aluminum oxide insulators between some MOSFETs
>>and their heat sinks and wanted to get a safety-related reality check.
>>I've checked the MSDS for aluminum oxide and it seems that as long as
>>I avoid breathing any dust and wash thoroughly after touching the
>>insulators, I'm OK.
>>But, I want to do some measurements of the MOSFET's case temperature
>>and need to grind a hole in the insulator. I have the Dremel and the
>>grinding bits to do it, but before I started I wanted to make sure I
>>did this carefully enough.
>>Will simply doing this outside in a decent breeze, or thoroughly
>>venting the dust if inside, be enough? Assuming I have safety glasses
>>on, etc.
>>One other question...
>>Has anyone actually experienced skin irritation to aluminum oxide
>>insulators? I can how a powder could do that but was wondering just
>>how nasty these insulators were to handle. :-)
>>Thanks!
>AlO2 is pretty benign. It's not toxic, so is as dangerous as any other
>dust... sawdust, glass, sand.
There are big differences in safety when these things are respirable
dusts. Sawdust, and probably alumina (aluminum oxide or corundum)
are typically in the "nuisance dust" category, although alumina at
high concentrations and/or long exposures is known to cause scarring
leading to Shaver's disease. Silica (silicon dioxide), however, is a
major component of sand and glass and is a much more serious problem.
When the particles are fine they cause permanent scarring, enough of
which leads to slicosis. Those who work with mineral dusts wear
respirators rated to remove this stuff. (NOT the silly little
"nuisance dust" masks sold to painters and woodworkers.)
>It's not a very good heat conductor. AlN is much better. BeO is even
>better, but BeO is seriously toxic.
Yeah , BeO is scary stuff! For airborne dust, it's 50 times more
toxic than Arsenic. Before I got into pottery and started
reading up on all this toxicity info, I acquired some TO3 BeO pads.
Now I think I'll just let them sit in their little plastic bags in
their little plastic parts drawer.... <g>
Best regards,
Bob Masta
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Signal Generator
Science with your sound card!
