Electronics Forums
Electronics Forums > Electronics Forums > General Electronics Chat > adapter question
Reply
Thread Tools Display Modes
adapter question
Junior Member
      01-14-2010, 11:19 PM
Hello,
I realize this is an extremely basic question but perhaps someone could at least point me in the right direction.
My router (wired) came with an adapter with the following numbers:
INPUT: 100-120V-0.5A 50-60Hz LF
OUTPUT: +5.0V -- 2A - == +
It stopped working (for unknown reasons).
The router works with another identical adapter but the original adapter does not provide power.
Can I use an adapter that has the following specs?
INPUT 100-240 V AC 50-60Hz
OUTPUT: 5V ------ 2A
Specifically: Would the 100-120V for input on the original be covered by the 100-240V?
Where can I find out what the numbers written on the adapters refer to?
Junior Member
      01-14-2010, 11:29 PM
Quote:
Originally Posted by VXtanyaXV View Post
Hello,
Assuming you are located where the line voltage is 120 volts, then the replacement is fine.
The 50-60 hz in line frequency and the output is 5volts @ 2 amps.
Junior Member
      01-15-2010, 01:32 AM
Thank you!
Super Moderator
      01-15-2010, 07:00 AM
Power in & out is ok, but:
Observe the polarity (symbol +C*- means center is negative, -C*+ means center is positive).
(the * is actually a dot in the center of the C, representing the physical layout of the plug)
Most power adapters have the center as the negative pole. Chargers usually have a positive center post.
Junior Member
      01-15-2010, 02:18 PM
Hi and thank you.
What I can read are the following:
The Original adapter:
- C* +
The potential replacement adapter:
- C* +
So this would mean both adapters have the center as Positive?
Thanks again
Super Moderator
      01-15-2010, 03:25 PM
Yes it does, so you're good to go on all electrical aspects, but I forgot to ask if the center pin fits in the center hole. They are usually 2.1mm but can also be bigger (2.3mm). If the pin is 2.1 and the hole 2.3 it will still work but feels wobbly. It won't fit the other way around of course.
Junior Member
      01-15-2010, 04:23 PM
Thanks for pointing this out! The original (broken) adapter's pin is significantly larger. It appears to have a yellow tip. So the potential replacement would wobble. Is there something to wrap around the narrow tip so it won't wobble? (BTW I have not tried it yet)
I found another adapter with a pin which would fit (It is "class 2" though)
Input AC 120V 60Hz 6.5 watts
Output 6VDC 200mA
-C*+
(It is for a land - line telephone)
I Found 1 more adapter for a scanner:
AC Input: 100V-120VAC 50/60Hz 25VA
DC Output: +12V === 1.25 A
V- O* V+ (I guess the circle replaces C? So this would have a positive center as well?)
Thanks again for your help!
Super Moderator
      01-15-2010, 09:28 PM
Neither of the last ones will work at all. You'll just have to try put in the replacement. If the outer was larger then the center pin may be large too. If it doesn't fit I'm not quite sure what to recommend. Plugs/ leads may be swapped but it requires tools & solder skills.
Last polarity makes no sense btw., could be a misprint, maybe a magnifying glass can reveal some more details.
Junior Member
      01-16-2010, 06:26 PM
Thanks for replying.
The potential replacement will not fit - as you mention the center pin is too large.
In the mean time, the original "broken" adapter works now. (Maybe carrying it around did something?)
I don't see any more with a magnifying glass re: the polarity.
(AC Input: 100V-120VAC 50/60Hz 25VA
V- O* V+)
V - O V+
The center of the diagram (the bolded O) is like a donut with an outer ring and an inner ring:
The V – has a line ending on the outer (larger) ring; the V+ has a line ending on the inner ring.
It is a Bestec
Model number: BPA-201S-12
I.T.E. power supply
Level 3
Thanks very much!
Super Moderator
      01-16-2010, 06:43 PM
Ok! Maybe it has a fracture inside, or a break in the wire, that has shifted and is now in connection. Hold it there, don't move, don't breathe!
Quote: "The V – has a line ending on the outer (larger) ring; the V+ has a line ending on the inner ring."
Ah, there's the giveaway; center positive. Sometimes they don't open the outer ring into a C, making it difficult to see where the center connection passes through..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
dc adapter question spampy General Electronics 2 02-26-2004 01:50 AM
Ac adapter amp question ElectricWind Electronic Basics 6 12-09-2003 01:10 PM
AC adapter - easy question, I hope Rick Electronic Basics 2 10-09-2003 04:27 PM
Another LED Question (Was: AC/DC adapter for LEDs) Kevin Dressel Electronic Design 7 07-05-2003 01:09 PM
Another LED Question (Was: AC/DC adapter for LEDs) Kevin Dressel Electronic Basics 7 07-05-2003 01:09 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
