On Wed, 11 Feb 2004 02:07:13 GMT
Codifus <(E-Mail Removed)> wrote:
> He was using his line out from the soundcard to the amp. SPDIF was not
> an option. It's quite easily possible. If you look at a Winamp EQ, the
> boost settings are quite large, and if you un-check the auto checkbox,
> which he did, the signals get boosted without any max output level
> correction by software, then the input stages of an amplifier will be
> hurting.
No, they wont.
no matter HOW much 'eq' he put on the winamp soft eq, the line output will not have (if it really was a line out) put out more than about 1V p-t-p.
some old equiment used 0.5V p-t-p but modern stuff is generally 1V p-t-p.
if he got winamp to produce some really high ouput LF square wave output its a possibility that if his amp was turn up a bit much he could have damaged his tweeters. but its not very likely, as you said - it wasnt loud.
Spyros lair:
http://www.mnementh.co.uk/ |||| Maintainer: arm26 linux
Do not meddle in the affairs of Dragons, for you are tasty and good with ketchup.
