Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > AC Motor braking resistors
Reply
Thread Tools Display Modes
Guest
Posts: n/a
      07-05-2005, 11:58 PM
Hello, can someone give me a explanation on how braking resistors work on AC
motors controlled by a VFD?
Thanks, Dave
Fred
Guest
Posts: n/a
      07-06-2005, 09:32 AM
Correct me if I'm wrong but I believe that AC motors are braked by
introducing a DC current across the stator windings??
Fred
<(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> The only place for motor energy to go is into the load or into the
> resistor. To slow the motor the drive the energy has to go somwhere,
> its only path is back through the IGBT or similar device back to the
> DC bus, where a resistor bleeds off the excess energy to keep the DC
> voltage under control.
> The AC/DC converter on the front end is different for a regenerative
> AC drive. SCRs vs. diodes. It lets you shut off or otherwise control
> the incoming power to control the braking.
>>AC
>>Thanks, Dave
Ted Rubberford
Guest
Posts: n/a
      07-06-2005, 05:47 PM
"Fred" <(E-Mail Removed)> wrote in message
news:syNye.1875618$6l.883601@pd7tw2no...
> Fred
Read the post again boy, "motors controlled by a VFD"
Teddy Rubberford.
Bizarre Bugger...
>>>AC
>>>Thanks, Dave
Guest
Posts: n/a
      07-11-2005, 07:38 AM
Actually, most VFDs do both. Dynamic Braking, i.e. using the braking
resistors, is a good way to bring the motor down CLOSE to a stop, but
as the motor slows, the energy in it becomes less andless, so the
braking energy that can go into the resistors becomes less as well. So
at some point, the law of diminishing return takes over, and you have
to finish the job using DC injection braking.
On Wed, 6 Jul 2005 18:47:57 +0100, "Ted Rubberford"
>> Fred
>Teddy Rubberford.
>Bizarre Bugger...
>>>>AC
>>>>Thanks, Dave
Ignacio Simón Yarza
Guest
Posts: n/a
      07-17-2005, 02:20 PM
Hello,
I will pipoint some issues that may clarify the facts:
1) VFD FOC techniques try to get equivalent behaviour to inverse braking but
in such a way that differential speed between stator and rotor magnetic
fields is controlled. A lagged field which makes rotor speed slow down is
produced on stator windings. But then, Where does the kinetic energy goes?
2) These rotor and stator magnetic fields result in two differential
voltages. The difference between them yields a voltage vector which
generates a current flowing back into the VFD. This is an energy returning
path which accounts for the dissipation of kinetic energy on the rotor axle.
3) The additional point to be clarified is why using this braking technology
instead of using a magnetic field acting proportionally to axle speed?? just
for the same reason for which VFD are used instead of direct feeding of
motor. As FOC theories allow treating AC motors as if they were DC
control-prone motors, so does VFD braking. In case Thyristor bridge is well
dimensioned, any braking curve may be obtained. On the contrary, DC braking
is cheaper but on its basic development it only allows a damped braking,
with a counter-force proportional to speed, and a mechanical brake works
always at the end of the braking cycle.
Best Regards.
Ignacio Simón Yarza.
Mech eng
Electronic and automatism eng
"Bob" <(E-Mail Removed)> escribió en el mensaje
news(E-Mail Removed)...
>>> Fred
>>Teddy Rubberford.
>>Bizarre Bugger...
>>>>>on
>>>>>AC
>>>>>Thanks, Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Regenerative braking dc motor controller calhau0 Circuit Help 10 04-23-2012 05:23 PM
Re: Braking of Universal Motor Ilevl Urplanet Electrical Engineering 2 09-24-2008 06:42 PM
A couple more motor control questions - Braking Echinos Electronic Basics 12 07-27-2007 10:33 PM
DC Motor Driver Regenerative Braking Humphrey B. Bear Electronic Design 12 08-04-2006 12:42 PM
Some considerations on AC Motor braking resistors Ignacio Simón Yarza Electrical Engineering 0 07-18-2005 01:42 PM
