Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > 555 timer control of solenoid actuator
Reply
Thread Tools Display Modes
Junior Member
      02-08-2010, 05:41 PM
I have this monostable 555 timer circuit that works fine with a LED (+resistor), but with a 12V solenoid actuator, it just opens but it does not close. The solenoid works fine when connected directly to the 12V source. Ideas about what could be wrong would be very welcome.
Super Moderator
(*steve*)'s Avatar
Location: Mid way between Beijing and the the Ronne Ice Shelf (mind your projection)
      02-08-2010, 06:33 PM
It sounds like your 12V solenoid requires more current than the 555 can supply.
Have a look for 555 circuits using a bipolar transistor, a mosfet or a relay to drive heavier loads.
Also don't forget to place a diode across your solenoid (or relay if you use one) to protect your 555.
This has a few examples.
Junior Member
      02-08-2010, 07:25 PM
Thank you *steve*, that is very helpful. If the current is too low, how come the solenoid stays open? Does it prevent the timer from running out?
Super Moderator
      02-08-2010, 07:31 PM
A 555 is rated to supply up to 100mA. Above that the output voltage sags.
A relay & a solenoid requires a lot more current to pull than to stay pulled.
Example; a 12V relay may pull at 9V but may release at only 3V.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
The difference between using one 555 timer and a 556 timer for PWM control Mr. J D Electronic Basics 8 08-17-2006 11:45 AM
ISC2006, June 5-7, 2006, Palermo, Italy, CFP Philippe Geril General Electronics 0 11-08-2005 02:50 PM
CFP: CALL FOR PAPERS. Special Issue: Operational Control of Wafer Production. Production Planning & Control International Journal Rubén Ruiz Electronic Components 0 07-26-2004 03:52 PM
CFP: CALL FOR PAPERS. Special Issue: Operational Control of Wafer Production. Production Planning & Control International Journal Rubén Ruiz Electronic Basics 0 07-26-2004 03:52 PM
Current mode solenoid driver Chris Carlen Electronic Design 3 08-08-2003 12:16 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
