Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > 4 V gel cell for Tek 222PS scope
Reply
Thread Tools Display Modes
mroberds@worldnet.att.net
Guest
Posts: n/a
      04-21-2005, 11:25 AM
Hello all!
I am looking for a replacement battery for a Tektronix "Power Scout"
222PS portable scope. The original battery supplied by Tek consists
of two Panasonic 4 V 2.2 Ah/20h gel cell batteries glued together and
wired in series. The Tek label rates this combination at 8.0 V,
2.1 Ah/10h and gives the part number as 146-0075-00. (This same battery
may have been used in the other portable scopes like this one, like maybe
the 222/A and 224.)
The Panasonic part number for each battery is LC-2042R1PU . I can't
find this number, but they are the same size, shape, and terminal
configuration as the (discontinued) LCS-214P,
http://www.panasonic.com/industrial/...scontinued.pdf
.. (Tek welded some tabs onto the battery terminals to connect the wires
to.) I have checked some of the usual suspects (Power Sonic, CSB,
Yuasa/Enersys, and Sonnenschein) and none of them make exactly this
battery. Power Sonic makes some 4 V batteries that are physically and
electrically too big. They also make an 8 V 3.2 Ah battery
http://www.power-sonic.com/ps-832.pdf that will almost fit in
the hole except it's just a bit too long (the 5.3"/134 mm dimension).
If I can't find the right battery, I have other options. I sort of want
to stay with lead-acid or with something that has a compatible charging
requirement so I can keep using the charger built into the scope. If I
can find a 12 V battery that fits in the hole, I can run it into the
external power jack on the scope, but then I have to come up with a
separate charger for the battery. Or, maybe I can stack up some NiCd,
NiMH, or 2 V SLA cells to get there.
Any tips or leads will be appreciated. Thanks!
Matt Roberds
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Testing Nicad/nicd or NiMH cell ESR or SLA Gel Cell Battery InternalResistance mike Electronic Repair 9 01-19-2010 12:41 AM
Re: Testing Nicad/nicd or NiMH cell ESR or SLA Gel Cell Battery Internal Resistance Phil Allison Electronic Repair 5 01-17-2010 02:20 AM
PowerScout 222PS tekscout Datasheets, Schematics, Manuals and Parts 0 04-19-2008 01:14 PM
4 V gel cell for Tek 222PS scope mroberds@worldnet.att.net Electronic Repair 4 04-21-2005 07:47 PM
Re: Need Tek IC # 155-0049-02 for Tek 468 scope Thomas P. Gootee Electronic Repair 0 08-29-2003 02:13 PM
