Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > 240 Volt AC To 12 Volt DC
Reply
Thread Tools Display Modes
Dave.H
Guest
Posts: n/a
      12-07-2007, 12:09 PM
I was wondering if it was possible to build a power supply that steps
the 240 Volts AC mains to 12 volt DC 200 mA. I know I could use a
wall transformer, but that would be to bulky for my little Tunecast II
FM Transmitter.
Tim Wescott
Guest
Posts: n/a
      12-07-2007, 03:47 PM
> the 240 Volts AC mains to 12 volt DC 200 mA. I know I could use a wall
> transformer, but that would be to bulky for my little Tunecast II FM
> Transmitter.
You basically have the choice of using a transformer-rectifier-regulator
supply, which will pretty much be a wall wart, or using an off-line
switcher. In the US the wall warts have all gotten smaller because
they're off-line switchers now -- has this not happened in the 240VAC
countries?
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Brendan Gillatt
Guest
Posts: n/a
      12-07-2007, 06:12 PM
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
>> Transmitter.
> countries?
I'd say about half of the wall warts I have in the UK are switchers. It's
only the _really_ cheap stuff that still has a transformer in.
My advice to the OP is to get a phone charger that outputs 9v DC - that
little gizmo will happily run from it. They're cheap enough and nearly
all are switchers.
Brendan Gillatt
brendan {at} brendangillatt {dot} co {dot} uk
http://www.brendangillatt.co.uk
PGP Key: http://pgp.mit.edu:11371/pks/lookup?...rch=0xBACD7433
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (MingW32)
iD8DBQFHWYz+kA9dCbrNdDMRAskoAJ93kv9Rbw++m9cTL3CQGA N4/ApSFgCfQSH9
ZxkaJSiYROhkP9eqlryldIQ=
=P/PT
-----END PGP SIGNATURE-----
Dave.H
Guest
Posts: n/a
      12-07-2007, 11:55 PM
On Dec 8, 5:12 am, Brendan Gillatt
> Hash: SHA1
> >> Transmitter.
> > countries?
> all are switchers.
> Brendan Gillatt
> brendan {at} brendangillatt {dot} co {dot} ukhttp://www.brendangillatt.co.uk
> PGP Key:http://pgp.mit.edu:11371/pks/lookup?...rch=0xBACD7433
> =P/PT
I'll have a look at Dick Smith Electronics.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Washing machine 240, 50Hz - 240, 60 Hz? Andrew Gabriel Electrical Engineering 70 11-25-2006 06:33 PM
Re: Washing machine 240, 50Hz - 240, 60 Hz? phil-news-nospam@ipal.net Electrical Engineering 0 11-02-2006 02:18 AM
60 amp single pahese 240 volt AC supply (UK) Chris Electronic Basics 11 12-15-2005 09:50 PM
8 Channel PCI DVR Card 240 FPS / 240 FPS juzer.yamani@gmail.com Security Alarms 1 07-19-2005 11:40 PM
Putting a motor thats 240/1/50 cycle on 240/1/60 ??? RVing Is Alot Of Fun Electrical Engineering 2 06-09-2005 06:27 AM
