Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > 120vDC to 120v AC invertor
Reply
Thread Tools Display Modes
Chris
Guest
Posts: n/a
      08-23-2005, 02:55 PM
Hi all,
I have tried searching for a solution to no avail. I have an older Lincoln
welder that is generating 120vdc to a standard outlet. At the start I
thought it was AC as power saw would run fine. Not until I tried to hook up
a cap start compressor did the smoke tell me something was wrong. After
checking everything I could check, I in fact learned that it was a true
generator as it was creating 120vdc. How the saws are running I have no
idea. Unless they are universal motors??????
Now I come to my question, getting the DC to AC. Actually the term inverter
might be wrong as I do not need to change voltage. Should I be asking for
an oscillator? Either way I need to get the DC into a sine wave. Not too
picky how true it is, I just need it to run motors, more or less, at a home
construction sight (read no solid state running off of it).
So is there a simple circuit I can devise, or any off the shelf solutions I
can use? Keep in mind that the unit is rated at 15amps = 1800 watts (BTW no
breaker or fuse on it at all, which I will correct). 1800 watt new
generators are about $400 or less, so keeping it under that cost would be
nice.
Any pointers, help, flames, appreciated.
Chris
Chris
Guest
Posts: n/a
      08-23-2005, 05:38 PM
Sue,
Yes I was thinking about a UPS. I have an older one lying around. Almost
tempted to just plug it in and see how it likes seeing only DC coming in.
Umfortunly it has two 24dc batteries, giving 48vdc to the controller. Step
down transformer comes to mind. I have a few, but the closest I have is
120v down to 80v.
What to do,
Chris
"Palindr?me" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> Chris wrote:
> > Hi all,
Lincoln
hook up
inverter
for
too
home
solutions I
(BTW no
be
> > nice.
> What may be worth looking at is a computer UPS. I have one which has 10
> x 12 volt sealed lead acid battieries inside and terminals* to connect
> an external 120vdc battery bank. It generates 3kVA.
> Only a few UPS use 120v dc internally - some use 48v, some 72v and some
> 12 v or 24 v. I suspect that, the higher the rating of the UPS, the
> higher the internal dc voltage used, within reason! But you would need
> to find a 120v one, ideally with external battery bank connectors to
> connect to.
> * You cannot use ac-rated kit such as contactors and switches with dc
> unless the manufacturer says so - and then it will be massively
> de-rated. I got hold of some high current dc stuff from a Government
> surplus place - I think they may have come from a submarine..I also have
> some lovely ebony-handled, spring loaded open frame knife switches -
> which are rated for 120 v dc. I only use them on 24v...to comply with
> IEE regs.
> Sue
> But it may be worth looking around.
Chris
Guest
Posts: n/a
      08-23-2005, 06:16 PM
Sue,
You caught me on the transformer. I am still thinking that it is AC coming
out of the welder. Still cannot beleive that they would bump that much DC
at 15 amps out to a regular AC plug (yes it was designed that way, way back
then). Worse yet, no breaker or fuse.
Chris
> Chris wrote:
> > Sue,
Almost
in.
Step
> > 120v down to 80v.
> You cannot use a transformer on dc. Sorry about that. And no, you
> wouldn't connect your dc supply to the ac input of the UPS - it wouldn't
> like that at all. You would connect your dc supply in place of the 120 v
> battery bank. Now, if you had a 48 v dc supply, you would be all set
> with your existing ups. Try shopping around for a different UPS - I paid
> 100 GBP for mine, without batteries. They are often on ebay.
> You are probably aware that dc is scary stuff. It can really set your
> house on fire. IIUC dc shocks are particularly nasty as they tend to
> leave you gripping the wires, rather than throwing you away. I have been
> very, very careful to avoid getting one.
> Sue
repatch
Guest
Posts: n/a
      08-23-2005, 06:50 PM
Frankly, with what you've said in this post I think the best course of
action would either be to drop the idea completely, or at least hire a
professional to do the work.
Transformers don't work at DC, they tend to blow up and start fires...
On Tue, 23 Aug 2005 13:38:50 -0400, Chris wrote:
> Sue,
> Step down transformer comes to mind. I have a few, but the closest I have
> is 120v down to 80v.
> What to do,
> Chris
>> Chris wrote:
>> > Hi all,
> Lincoln
> hook up
>> > After checking everything I could check, I in fact learned that it was
>> > a true generator as it was creating 120vdc. How the saws are running
>> > I have no idea. Unless they are universal motors??????
> inverter
> for
> too
> home
> solutions I
> (BTW no
> be
>> > nice.
>> connect to.
>> IEE regs.
>> Sue
ehsjr
Guest
Posts: n/a
      08-23-2005, 07:38 PM
Chris wrote:
> Hi all,
> nice.
> Thanks,
> Chris
I would say be prepared to give up the idea. A PC UPS will not work
for you, unless you intend to use low power motors. Your compressor
probably needs FAR more power than a typical PC ups can provide.
You might be better served by buying a generator sized to your needs.
Ed
Chris
Guest
Posts: n/a
      08-23-2005, 08:29 PM
"ehsjr" <(E-Mail Removed)> wrote in message
news:jXKOe.2476$IG2.1014@trndny01...
> Chris wrote:
> > Hi all,
Lincoln
hook up
inverter
for
too
home
solutions I
(BTW no
be
> > nice.
> > Thanks,
> > Chris
> Ed
Already canned the idea for the sake of safety.and cost plus I still have
the welder.
Actually the UPS that I have is good to 2250watts, more than enough to drive
a 3/4 hp compressor.
Thanks again all,
C
Don Kelly
Guest
Posts: n/a
      08-24-2005, 02:44 AM
"Chris" <(E-Mail Removed)> wrote in message
news:bGLOe.4360$(E-Mail Removed)...
>> Chris wrote:
>> > Hi all,
> Lincoln
> hook up
>> > After
>> > no
> inverter
> for
> too
> home
> solutions I
> (BTW no
> be
>> > nice.
>> > Thanks,
>> > Chris
>> Ed
> the welder.
> drive
> Thanks again all,
> C
Can it handle the starting inrush current?
Don Kelly @shawcross.ca
remove the X to answer
ehsjr
Guest
Posts: n/a
      08-25-2005, 06:05 AM
>>Chris wrote:
>>>Hi all,
> Lincoln
> hook up
> inverter
> for
> too
> home
> solutions I
> (BTW no
> be
>>>nice.
>>>Thanks,
>>>Chris
>>Ed
> the welder.
> Thanks again all,
> C
Doubtful. Do you know what the compressor will draw
when starting?
Ed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Difference between a normal invertor and a hex invertor? Ben Electronic Basics 11 04-20-2006 09:44 AM
Re: Will 120v/60Hz microwave ovens run at 120v/50Hz? John G Electrical Engineering 2 09-10-2005 03:06 AM
Re: Will 120v/60Hz microwave ovens run at 120v/50Hz? NunYa Bidness Electrical Engineering 6 09-10-2005 02:47 AM
Re: How to get 120V AC constant from varying input i.e 120V-277V Victor Roberts Lighting 0 06-17-2005 05:56 PM
Running 120v 60hz motors on 120v 50hz mrgrahamm@yahoo.com Misc Electronics 0 05-28-2005 03:34 AM
