Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > 12 volt Mains adaptor - query re amps
Reply
Thread Tools Display Modes
matt
Guest
Posts: n/a
      04-17-2006, 07:46 PM
The mains adaptor for my router (a Cisco Wireless-G WAG54G) has just
died a death - the router's power requirements are 12volts at 1amp. I
have a spare 12volt mains adaptor but it's only rated at 500mA. I've
tried it and all seems well, but am I likely to experience problems
using it with the 1amp router?
If so, would the worst thing to happen be the failure of the mains
adaptor?
Just to be on the safe side, should I obtain one rated at 1 amp?
Ryan Weihl
Guest
Posts: n/a
      04-17-2006, 08:16 PM
> adaptor?
> Thanks
does it get hot????
Ryan Weihl
Guest
Posts: n/a
      04-17-2006, 08:18 PM
> adaptor?
> Thanks
does it still produce 12volts. what AC or DC??
John Fields
Guest
Posts: n/a
      04-17-2006, 08:37 PM
On Mon, 17 Apr 2006 19:46:54 GMT, matt-(E-Mail Removed) (matt)
More than likely what'll happen, long term, is that you'll overheat
the transformer in the adaptor and it'll fail prematurely. Also,
you could exceed the ripple current spec of the reservoir capacitor,
causing it to fail prematurery.
>adaptor?
Who knows? if it's not fused and it overheats and catches fire,
there might go your house.
Of course.
John Fields
Professional Circuit Designer
matt
Guest
Posts: n/a
      04-17-2006, 08:51 PM
On Mon, 17 Apr 2006 15:37:12 -0500, John Fields
<(E-Mail Removed)> wrote:
Thanks for the replies - I'll buy one rated at 1A then.
BTW, it's 12 volts DC.
Rich Grise
Guest
Posts: n/a
      04-17-2006, 10:06 PM
> adaptor?
Yes - that's the proper way to do it. You say you've tried the 500 mA
adapter and it "seems" well, but I'd check how hot it's getting - if
you only run the router at 50% duty cycle or less, you might get away
with it, at least until the adapter melts. ;-)
Good Luck!
Rich
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: hum on digital recorder but only when using mains adaptor krw@att.bizzzzzzzzzzzz Electronic Basics 0 10-24-2011 07:56 PM
Dummy load testing of amps query N Cook Electronic Repair 7 03-29-2007 03:25 PM
amps adaptor for DMM Sawney Beane Electrical Engineering 6 12-15-2005 08:08 AM
AC adaptor I need is 6-8v 50-100ma. Adaptor I have is 3-6-9v and 300ma max. Is that okay? Darren Electronic Basics 3 07-19-2005 04:43 PM
Mains Adaptor JSGJones Beginner Electronics 2 06-26-2005 02:45 AM
