Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > 12 volt automotive fan speed controller
Reply
Thread Tools Display Modes
mark krawczuk
Guest
Posts: n/a
      11-25-2007, 05:14 AM
hi, i am after a basic type schematic to controll the speed of a 12 volt
dc automotive cabin fan .
seems to be a bit of a problem in these saab`s.
any schematic using a mj11032 or mj11016 darlington would be good. if
not any electronic speed controll schematic will be fine.
the original darlington is rated at about 25 amp , seems a bit excessive....
these darlingtons i have are rated at 30 and 50 amp.
thanks, mark k
gregmhand@gmail.com
Guest
Posts: n/a
      11-25-2007, 06:05 AM
> thanks, mark k
Mark,
How do you want to control the speed of your fan? Is it based off of
cabin heat? a user? something else?
mark krawczuk
Guest
Posts: n/a
      11-25-2007, 12:44 PM
hi, sorry , i suppose i should have said, i just need a potentiometer to
control the speed , it doesnt need to be controlled by cabin heat
etc...., the fan controller in my car isnt working and they havea tendency
to fail , so i am trying to construct a bit more robust one . everything
is working fine the heat , aircon , its just that the factory controller
is broken and the fan always stays on really low,.
thanks,
mark k
<(E-Mail Removed)> wrote in message
news:81fc40b7-7b49-47c2-ac00-(E-Mail Removed)...
>> volt
>> if
>> excessive....
>> thanks, mark k
> Mark,
melee5@my-deja.com
Guest
Posts: n/a
      11-25-2007, 10:29 PM
> thanks,
> mark k
> <gregmh...@gmail.com> wrote in message
> >> volt
> >> if
> >> excessive....
> >> thanks, mark k
> > Mark,
> > cabin heat? a user? something else?- Hide quoted text -
> - Show quoted text -
Sorry, I don't have a schematic for you, just a couple of ideas and
pointers. 25 amps is NOT overkill by any means as most heater blowers
will pull that much easily. So I would not use your 30 amp darlington
and would only feel good about your 50 IF it had a real good heat sink
arrangement.
Most auto heater blowers use wind cooled wire wound resistors in
series with the blower motor circuit to attain low and medium speeds
with high speed being a direct connection to 12+ volts. Some
regulatory body specifies that a super low speed is mandated to be on
all the time to guard against carbon monoxide poisoning, which is
probably the low speed you've noticed.
What typically happens is the connection between the standard copper
based slip on connectors corrodes with the ni-chrome wire of the wire
wound resistors in the fan speed circuits. Silver soldering the
connections maybe an easier solution?
If I were to build a circuit for your application I would use UA78s40
switching IC to drive the darlington that would drive a torroid step
down/step up circuit. Switching in different resistors in the
voltage feedback circuit would then select fan speeds. And in my old
Subaru for example, I also need to hit the fan motor with some 16-17
volts in order to have me a super high speed for those really cold
winter days.
Jim Thompson
Guest
Posts: n/a
      11-25-2007, 11:03 PM
>> thanks,
>> mark k
[snip]
>Most
CHEAP
[snip]
The controller design I did for Bosch (Bühlertal, Germany) for
inclusion in the Mercedes AC/heat system was a 3-phase electronically
commutated motor... custom microchip plus 3 N-channel MOSFET's...
continuously variable speed, but controlled acceleration (so that the
chief engineer couldn't hear any whine when he stuck his head in the
air duct ;-)
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice480)460-2350 | |
| E-mail Address at Website Fax480)460-2142 | Brass Rat |
| http://www.analog-innovations.com | 1962 |
America: Land of the Free, Because of the Brave
melee5@my-deja.com
Guest
Posts: n/a
      11-27-2007, 03:15 AM
On Nov 25, 4:03 pm, Jim Thompson <To-Email-Use-The-Envelope-I...@My-
Web-Site.com> wrote:
> >> hi, sorry , i suppose i should have said, i just need a potentiometerto
> >> thanks,
> >> mark k
> [snip]
> >Most
> CHEAP
> [snip]
> air duct ;-)
> ...Jim Thompson
So where is your schematic?
Jim Thompson
Guest
Posts: n/a
      11-27-2007, 02:28 PM
>> >> thanks,
>> >> mark k
>> [snip]
>> >Most
>> CHEAP
>> [snip]
>> air duct ;-)
>> ...Jim Thompson
It predates CAD, is pencil on D-sized.
I'll see if I can scan a reasonable copy.
Keep in mind, it's a CHIP... thus HUNDREDS of transistors.
...Jim Thompson
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
12 volt fan to 12 volt transformer christian231 General Electronics Chat 8 06-24-2010 02:57 PM
12 volt automotive fan speed controller mark krawczuk Electronic Components 3 12-03-2007 01:21 AM
12 volt automotive fan speed controller mark krawczuk General Electronics 1 11-27-2007 09:57 PM
12 volt automotive fan speed controller mark krawczuk Electronic Basics 0 11-25-2007 05:13 AM
fan speed controller hunnimonstr@msn.com Electronic Design 18 01-14-2004 05:10 AM
