Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > 0 to 99 counter
Reply
Thread Tools Display Modes
0 to 99 counter
heman_too_cool@yahoo.co.in
Guest
Posts: n/a
      02-09-2007, 02:18 PM
I want to make 0 to 99 counter using 4029 and some other necessary
chips . How can I do this ?
mkaras
Guest
Posts: n/a
      02-09-2007, 02:42 PM
This should be relatively easy if you have the CD4029's already. One
of these chips can count from 0 to 9 provided you set the BINARY/
DECADE (pin-9) to a low level. Also put the UP/DOWN (pin-10) of this
part to a high level to enable counting in the upwards direction.
Counting to 99 will require two of the CD4029s. Connect the pin-9 and
pin-10 of both parts as discussed above. Also wire the PRESET input
(pin-2) on both parts to a low level. Wire the clocks in common to
both parts and connect to whatever it is that will advance the count.
On the first device (low digit counter) make sure to set the CARRY_IN
(pin-5) to a low level. Then take the CARRY_OUT (pin-7) of the first
counter and wire it to the CARRY_IN (pin-5) of the secound counter.
This latter connection allows the second high digit counter to step
only when the low digit counter is rolling over from nine back to
zero.
Since these are CMOS parts it is advisable to also tie all of the
JAM_LOAD (pins 3, 4, 12 and 13) inputs to low levels at both chips.
For the basic counter you desire no other chips should be required to
implement the 0-99 count sequence.
- mkaras
Don Lancaster
Guest
Posts: n/a
      02-09-2007, 03:45 PM
Sell the chips and buy a Basic Stamp, of course.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: (E-Mail Removed)
Please visit my GURU's LAIR web site at http://www.tinaja.com
a7yvm109gf5d1@netzero.com
Guest
Posts: n/a
      02-09-2007, 03:48 PM
Zing! Yeah what's the deal with 4000-series CMOS in 2007?
John Larkin
Guest
Posts: n/a
      02-09-2007, 04:38 PM
"Too cool"! That's hilarious.
John
Spehro Pefhany
Guest
Posts: n/a
      02-09-2007, 05:44 PM
On Fri, 09 Feb 2007 08:38:00 -0800, the renowned John Larkin
>John
I can visualize him now. Mr. Bollywood.
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
(E-Mail Removed) Info for manufacturers: http://www.trexon.com
Embedded software/hardware/analog Info for designers: http://www.speff.com
Jan Panteltje
Guest
Posts: n/a
      02-09-2007, 05:47 PM
On a sunny day (9 Feb 2007 06:18:59 -0800) it happened
(E-Mail Removed) wrote in
<(E-Mail Removed) .com>:
Use a PIC micro controller, and glue the 4029 on top.
Rich Grise, Plainclothes Hippie
Guest
Posts: n/a
      02-09-2007, 07:14 PM
Get two 4029s, and connect them together in the right order.
Good Luck!
Rich
me
Guest
Posts: n/a
      02-09-2007, 07:25 PM
(E-Mail Removed) wrote in news:1171030739.536650.229460
@j27g2000cwj.googlegroups.com:
Apply wire, solder, power, and a little book learnin'...
not necessarily in that order...
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
krw
Guest
Posts: n/a
      02-09-2007, 08:12 PM
In article <(E-Mail Removed)> ,
(E-Mail Removed) says...
It doesn't matter which order the 4029s are connected. ;-)
Keith
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
High-speed counter for frequency counter project Ben Jackson Electronic Design 10 07-05-2006 06:51 PM
Design of counter Kumar Appaiah General Electronics 9 09-25-2004 03:27 PM
WANTED - - Wire Measurer -or- Wire Meter -or- Wire Counter Bill Hansen General Electronics 0 08-21-2004 10:40 PM
Counter interface? George Francis General Electronics 2 02-28-2004 02:20 PM
FS: Frequency meter, Counter, timer Robert Baer General Electronics 0 11-10-2003 07:59 AM
